Tire track on R200 BO output
2005-08-31 by fitness2health
In frustration that I could not elimiate the color cast from B&W prints
on my Epson 1270, and dismayed with the lack of quality in BO, before
jumping in and buying the MIS UT FS set, I opened the Epson R200 box I
had in my basement for the last eight months (a freebee with my D70).
I was stunned by the quality of the BO prints. Obviously all my color
casts gone overnight, much less bronzing than on the 1270, deep blacks
(although it needs some tweaking to lessen contrast compared to my
monitor), and a visually tighter dot pattern with less apparent banding.
What has made me disappointed however, is something I can only describe
as a tire track. If I print a 10*8 solid grey test print, on the top
left corner of the print (the edge that exist the printer first), I get
a tonal difference that is a bar, about 1.5" from the left margin, .5"
wide and 2.25" high.  Under a loupe is looks indistinguishshable from
the rest of the print, but to the naked eye looks like a
stripe/bar/tire track.
I have run alignment, checked the nozzle pattern, changed the driver to
version 5.50, tried different paper - all to no avail.
Before I attempt to navigate through Epson support lines, has anyone
experienced such a thing and know of any likely causes.
many thanks
Keith
Re: Tire track on R200 BO output
2005-08-31 by Steven Karafyllakis
Hi Keith;
Sounds like the first cousin to the 'pizza wheel' tracks, the rubber
roller track. Run a piece of plain paper through right after a print
and see if maybe you get a similar track on it. If so, keep running
plain paper through until it comes out clean and try again.If that
is not the case, the only thing I can suggest, is if you are
using 'high speed' to turn that off, it might give the ink a bit
more time to dry before hitting the offending roller. BTW-you do
realise that the OEM inks in that printer are dyes, and have a
relatively short lifespan, yes?
Hope this helps
Steve Karafyllakis
BTW nice little freebie, yes?
-- In DigitalBlackandWhiteThePrint@yahoogroups.com, "fitness2health"
prints
before
box I
D70).
color
blacks
banding.
describe
top
I get
margin, .5"
from
driver to
anyone
> many thanks
> Keith
Steve,
thanks for the pointers. I presume that you are talking about the
roller that feeds the paper out of the hopper. This roller, however,
touches the paper before the inkject. I have tried high speed off,
but this did not change anything. I cannot see any indentation on the
front or rear of the paper. I might try cleaning the roller in case
it has some residue that is coating the paper before the ink hits.
I am surprised that this issue has not happened with others (or maybe
they don't print a 10*8 solid grey test page!).
BTW - Epson tech support was useless - referred me to a repair shop
200 miles away.
Regarding the inks, I was trying this printer before going to Eboni
ink - but am not now so sure - maybe I will stick with the 1270 and
the UT FS inkset.
Keith Prue
DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis"
<steve@s...> wrote:
> Hi Keith;
rubber
print
> Hope this helps
> Steve Karafyllakis
> -- In
> prints
> before
> box I
> D70).
> color
> blacks
my
> banding.
> describe
> top
> I get
> margin, .5"
> from
> driver to
> anyone
> > many thanks
> > Keith
RE: [Digital BW] Re: Tire track on R200 BO output
2005-08-31 by John Moody
Is it possibly the paper?  Cut it 8 ½ square and turn it 90 degrees.
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of
fitness2health
Sent: Wednesday, August 31, 2005 11:22 AM
Subject: [Digital BW] Re: Tire track on R200 BO output
Steve,
200 miles away.
the UT FS inkset.
Keith Prue
It is not the batch of paper, because it occurs on glossy and lustre,
but does not show on matte.
thanks anyway for the thought
Keith Prue
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Moody"
> Best regards,
> John Moody
> fitness2health
> Steve,
maybe
> 200 miles away.
> the UT FS inkset.
> Keith Prue
