Whats new in the world of Glop
2005-08-31 by Steven Karafyllakis
Hi all; Now that I have a printer that can use gloss optimizer, I'm hoping to find a 3rd party version that is clear enough not to affect the color of the highlight values. Has anyone bought the MIS recently? Has that been improved? What other choices (other than Epson that is) are out there that anyone has tried? Thanks Steve Karafyllakis
2005-08-31 by ccolbertbw
Steve. I bought and used MIS glop recenty. It is still tea-colored in the bottle. Using QTR, I set the value at a fixed 16000. On Kirkland paper it cut down almost all the gloss differential. As far as dulling the highlights, it didn't. I had set all the output values including 0. So although I printed an 5x7 on an 8x10 page, it was covering the nonimage portion with glop as well. I stopped it about half way down the page. Along the edge where there was a sharp border, you could only see the border if you held it just-right in the light. Where the printing stopped, and therefore transitioned smoothly from full glop to no glop, where only some head passes had completed, I couldn't find the border at all. There is a very slight decrease in the glossiness of the paper where the glop has been applied. My previous experience was not as successful. Apparently the cleaning cart that I used had some coloration in it and it took quite a while to flush all traces of color out. My nozzle checks showed a very faint gray, and my prints looked veiled. Now I can't see the nozzle check pattern at all on plain paper. (I haven't tried a nozzle check on Kirkland.) But the gloss differential is way down so something must be coming out. All in all I would say it seems to be working well. Costa --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis" <steve@s...> wrote:
> Hi all; > > Now that I have a printer that can use gloss optimizer, I'm hoping to > find a 3rd party version that is clear enough not to affect the color > of the highlight values. Has anyone bought the MIS recently? Has that > been improved? What other choices (other than Epson that is) are out > there that anyone has tried? > > Thanks > > Steve Karafyllakis
2005-08-31 by dfaprinting
I recently made a profile for a printer that used the WeInk set of inks for the 1800, and the GLOP had minimal color change to the paper white. It was printed on a luster paper, so I can't comment on how it would look on a full gloss paper.
This sound interesting-do you know what the glop looks like in a bottle? is it clear or tea-colored like the UC base fluid? As for your profile, did you set it up for full coverage, or proportional? I'm trying to use the Epson semi-matte, and was surprised to find that the Epson glop (applied either way) does a very inadequate job on that paper. The MIS does much better, but getting enough on the paper does affect the whites a bit. Steve --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dfaprinting" <dfaprinting@y...> wrote: > I recently made a profile for a printer that used the WeInk set of inks > for the 1800, and the GLOP had minimal color change to the paper white. > It was printed on a luster paper, so I can't comment on how it would > look on a full gloss paper.
Thanks, Costa; I will be getting some refillables soon, and since I have some MIS I will certainly try it again. Steve Karafyllakis --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ccolbertbw" <ccolbert@u...> wrote: > Steve. > I bought and used MIS glop recenty. It is still tea-colored in the bottle. Using QTR, I set > the value at a fixed 16000. On Kirkland paper it cut down almost all the gloss differential. > As far as dulling the highlights, it didn't. I had set all the output values including 0. So > although I printed an 5x7 on an 8x10 page, it was covering the nonimage portion with > glop as well. I stopped it about half way down the page. Along the edge where there was a > sharp border, you could only see the border if you held it just- right in the light. Where the > printing stopped, and therefore transitioned smoothly from full glop to no glop, where > only some head passes had completed, I couldn't find the border at all. There is a very > slight decrease in the glossiness of the paper where the glop has been applied. > > My previous experience was not as successful. Apparently the cleaning cart that I used had > some coloration in it and it took quite a while to flush all traces of color out. My nozzle > checks showed a very faint gray, and my prints looked veiled. Now I can't see the nozzle > check pattern at all on plain paper. (I haven't tried a nozzle check on Kirkland.) But the > gloss differential is way down so something must be coming out. All in all I would say it > seems to be working well. > > Costa > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis" <steve@s...> > wrote: > > Hi all; > > > > Now that I have a printer that can use gloss optimizer, I'm hoping to > > find a 3rd party version that is clear enough not to affect the color > > of the highlight values. Has anyone bought the MIS recently? Has that > > been improved? What other choices (other than Epson that is) are out
> > there that anyone has tried? > > > > Thanks > > > > Steve Karafyllakis
2005-08-31 by Steve Kale
I would take a look at the new base inks first - you may find you don't need glop or at least such a small amount that colour is not affected.
> From: Steven Karafyllakis <steve@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Wed, 31 Aug 2005 16:17:10 -0000 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: [Digital BW] Re: Whats new in the world of Glop > > Thanks, Costa; > > I will be getting some refillables soon, and since I have some MIS I > will certainly try it again. > > Steve Karafyllakis
That's a good point, Steve! Steve Karafyllakis --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale <stevekale@b...> wrote: > I would take a look at the new base inks first - you may find you don't need
> glop or at least such a small amount that colour is not affected. > > > > From: Steven Karafyllakis <steve@s...> > > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > > Date: Wed, 31 Aug 2005 16:17:10 -0000 > > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > > Subject: [Digital BW] Re: Whats new in the world of Glop > > > > Thanks, Costa; > > > > I will be getting some refillables soon, and since I have some MIS I > > will certainly try it again. > > > > Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis" <steve@s...> wrote: > This sound interesting-do you know what the glop looks like in a > bottle? is it clear or tea-colored like the UC base fluid? > > As for your profile, did you set it up for full coverage, or > proportional? I was making the profile for someone else, so I'm not entirely sure if it was full coverage, or only to fill in the white areas. The target was printed on Inkjet Art Micro Ceramic luster (same as Epson premium luster 250?) and the GLOP covered white area was more glossy than the unprinted paper. All the patches on the target had about the same amount of gloss if that helps.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis" <steve@s...> wrote: > That's a good point, Steve! > > Steve Karafyllakis > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale > <stevekale@b...> wrote: > > I would take a look at the new base inks first - you may find you > don't need > > glop or at least such a small amount that colour is not affected. > > Yes it is a good point.
