RE: [Digital BW] Questions regarding new UT7 ink base
2005-09-01 by Paul Roark
> ... MIS has changed the UT7 ink to use a glossier base.
Not glossier, just non-bronzing.
> Does the new formulation affect any existing curves (QTR or Paul's)?
I have not received the new inks, so I don't know.
> Can I mix the old and new inks in the same image?
> Can I mix the old and new inks in the same cart?
A few days ago there was a thread on this.  The base is chemically
compatible with the old base and Epson pigs.  With the color inks (MIS Pro),
the colors may be slightly different.  Thus MIS recommends not mixing.
Another member here has found them close enough that it's not a big deal if
you just add the new inks on top of the old.
