After wrestling with a MIS CFS on my 1280 without ever getting
reliable prints, I stuffed it in a drawer...I then saw the new clear
carts and thought they looked great (and I had all of that ink left
over). However, I have cleaned, purged, and printed until I am ready
to be fitted for restraints, and it simply will not print a complete
image without dropping nozzles.
I finally gave up and switched back to color dye. Perfect nozzle
checks immediately, and no issues.
I wonder if significant prior use with the color dye somehow makes the
printer unsuitable for pigments; maybe it's not possible to completely
remove all of the dried dye (if the prior owner let it sit - I bought
it used). I've heard others have good results if they started new
printers with the pigments. I have tried every cleaning trick I could
track down, including filling extra clear carts with a mix of
distilled water and ammonia. Nothing worked in the long term.
I'd love to try the new UT7/Pro inks in my 2200, but I'm afraid of
messing it up and then being unable to sell it.
Eric
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mark Hahn"
<markhahn2000@y...> wrote:
> Thanks... I guess I know all that... but I want to throw my printer
out
> the window at this point! I have a feeling that the carts are all
> defective. The poppet is really, really touchy in the black and
that
> is the worst (really had to wiggle the adapter around to get it to
open
> up for the priming step)... think one or two of the "color" set
were
> also weird. Off to a great start! Between the ink, carts and
paper
> order I have a feeling I just wasted $200 for nothing but a few
nights
> frustration :( I also have a clean CFS that I can use if these
> spongeless carts are really so terrible... first try I have 3
channels
> bad... makes it seem statisically unlikely that I would ever be
able to
> get a color cart in which all three channels worked :(
> ... the optimistic in me wanted to believe that with the new carts
and
> inksets that the system would actually work as advertised... at
least I
> wasn't so optimistic that I bought a new 1280 strictly for MIS inks
and
> everything to go with it... (I was close, but then figured I try
out
> the 1160 before spending $500 on the 1280 setup... the price of a
wide
> carriage HP or a good down payment on a R2400!).
> I've reprimed the carts 3 times. I've printed purge patterns until
> they were all gray. I've done more cleaning cycles than I should
have
> and the patterns change every time. The printer was giving perfect
> patterns with epson dye the minute before the installation of the
MIS
> spongeless carts. Am I missing something?
> Thanks,
> mark
"kenstrain2000"
> <kenstrain2000@y...> wrote:
> > Mark,
> > your struggles are familiar (with 1160,1270,1290 printers). AFAIK
it
> > is really important not to do more than 3 clean cycles without
> > stopping for a rest (for the printer) and (very important) then
do a
> > small print
> > (purge pattern).
> > The "cleans" are not all the same (short, medium and long), and I
> > think the pattern requires to be reset after a set of 3 to work
well.
> > Look for the cause of the problem - if a couple of sets of cleans
do
> > not fix it. There are many resources with advice (the old
mwords.co.uk
> > pages, MIS, etc. etc.), but thoughtful diagnosis is the best way
to a
