Re:FAQ? HP 8750 vs Epson 2400 for B&W
2005-09-09 by photoian@comcast.net
My suggestion is to dry mount it; I do that with all my prints , inkjet and other and have never had a problem. There are psa systems but my experience is that they ultimately start to let go and billow up toward the glass.
Ian
Message: 3
   Date: Thu, 08 Sep 2005 21:10:03 -0000
Subject: Re: FAQ? HP 8750 vs. Epson R2400 for B&W
ok, I was the one who mentioned HP Premium Plus Glossy puckering up and
contacting the glass when hinged behind an 8-ply museum mat.  If a
traditional archival hinged mat sandwich is the wrong way to mount this
paper, what are you saying is the right way to do it?
mark
RE: [Digital BW] Re:FAQ? HP 8750 vs Epson 2400 for B&W
2005-09-09 by John Moody
The PMA-568 adhesive comes with a hard plastic squeegee, and I suspect many
people don't really press it down thoroughly and completely, leading to
future release.
I use a rubber J roller, like what is used for laminating or veneering with
contact cement.  I assure you it is very permanent after that, and _can't_
be removed.
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of
photoian@...
Sent: Friday, September 09, 2005 1:07 PM
To: Group
Subject: [Digital BW] Re:FAQ? HP 8750 vs Epson 2400 for B&W
Ian
Message: 3
mark
Re: [Digital BW] Re:FAQ? HP 8750 vs Epson 2400 for B&W
2005-09-09 by Steve Kale
I would say the problem is a lack of adequate overlap of mat and print...
> Message: 3
>    From: "Mark Hahn" <markhahn2000@...>
> mark
2005-09-10 by Mark Hahn
And how does that reduce the image area from swelling?  With paper,
clamping boundary conditions have very little effect past several
inches... like at the center of a print.
I've experimented with this, the better solution is to print edge to
edge and cover the border with a neutral gray so that the paper more
or less swells equally.  The prints still swell variably with ink
density, but it is better.
What are you limiting your print size to?  Only print 8x10s on your
8750?
If you can't frame large prints from a 8750, then there isn't any
reason to make them so I guess there is no reason for anyone to
consider this printer in your opinion?
HP prints also take much more than a week to totally dry down, and
the worst problem I had was framing prints after only 8 days... but
sometimes you want to show brand new work and not just pull prints
that are months old...
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
print...
> > Message: 3
> >    From: "Mark Hahn" <markhahn2000@y...>
up and
mount this
> > mark
2005-09-16 by Mark Hahn
I have been told that museums will not touch mounted photos... and
even though there are no museums looking to purchase my prints ;) my
collectors are also somewhat aware of this and would prefer unmounted
photos.
mark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Moody"
suspect many
leading to
> future release.
veneering with
_can't_
> be removed.
> Best regards,
> John Moody
> photoian@c...
> To: Group
inkjet and
experience
glass.
> Ian
> Message: 3
and
this
> mark
2005-09-18 by Ben Rosengart
Interesting.  How come?
> and
> photos.
> mark
 Ben Rosengart                                          ben@...
       "Young people should be seen and not heard, because they're
        good-looking but not too bright.  We're pretty bright now,
        but we're ugly." -- Grace Slick on the '60s youth movement
