300ppi vs 360ppi
300ppi vs 360ppi
2005-09-17 by Steve Gledhill
There has been some discussion of this topic before herein but I guess
I failed to take real notice of it until the other day when I was
amazed to see a very rough edge to an angled black line on a print.
This line appeared as a very smooth edge on my screen.  This effect
appeared on any high contrast edge that ISN'T parallel to or
perpendicular to the image edge – i.e. it slopes or is angled across
the image.  The line was actually the edge of some large text
(specifically the letter `A') that I'd added to an image in Photoshop.
 This was sufficiently bad to be visible in the print to the naked eye
– and once noticed, it was obvious.  It's not some micro effect that
only a loupe would reveal.  Once I'd noticed it in the letter A I
realised it was in all of the sloping parts of the text AND in the
image area wherever there was a black or very dark sloping edge
against a much lighter area.
I tried all sorts of things including checking the head alignment, and
eventually printing on two different printers.  I then realised it
must be an artefact of the conversion by the Epson Driver from the
image resolution (300ppi) to whatever resolution the printer uses.
The thing that made me realise this was the fact that the exact same
problem was present when I made the same print from the same image
file sent to two different printers – a 2100 and a 4800.
For some images I've been using 300ppi as a standard for outputting
files to print.  But I remembered reading something about Epson
printers using multiples of 360ppi in the driver.  So I then tried the
same file resampled in Photoshop from 300ppi to 360ppi.  It totally
cured the rough jagged edge problem in the printed image.  I've since
confirmed by other tests that this was not simply as a result of the
resampling.  This problem seems to occur when you use some simple
fraction of 360ppi.  For example my 300ppi is 5/6 of the 360ppi, or
360ppi is 1/5 more than the 300ppi.  I haven't noticed this problem
when my image ppi is larger AND not a simple fraction of 360ppi.
I know that some people use 300ppi as it is often said that this is
the point at which pixels are no longer visible to the naked eye.  I
wonder whether your output to print is as sharp as it could be.  My
experience suggests that if you are printing from an image at 300ppi
using the Epson Driver, try resampling it to 360ppi in Photoshop for
printing existing images, and work at 360 ppi for future images.
I'm writing this up so that if there are others who've puzzled over
the cause of these jagged hard edges then at least there's a possible
explanation and cure available.  I somehow think that I can't be the
only printer who hasn't understood this and acted on it before!
I'm sure the maths used in resampling will explain this fully, but for
me avoiding it is what really matters.
Steve Gledhill
http://www.virtuallygrey.co.uk/
Re: [Digital BW] 300ppi vs 360ppi
2005-09-17 by Mark Savoia
Actually if you ever get that problem again, just change the res to
301ppi or 299 ppi and it will probably go away. I do not know the
reason - but it works. BTW I have always done the 360 ppi thing and
find it makes a difference on what size print you are making. A
larger print can do with lower setting (288 ppi) with no difference
in quality, and things RIP faster. Might depend on driver or RIP
being used although.
Mark
> perpendicular to the image edge � i.e. it slopes or is angled across
> � and once noticed, it was obvious.  It's not some micro effect that
> file sent to two different printers � a 2100 and a 4800.
> Steve Gledhill
> If you wish to receive no emails or just a daily digest, or you
> wish to unsubscribe, please edit your Membership preferences by
> visiting this same page.
> - As threads develop, trim off excess portions of earlier messages
> to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> - By posting on this forum you agree to abide by the group rules
> and guidelines, and to abide by the actions and decisions of the
> group Owner and Moderators. See �Group Topic, Rules and Guidelines�
> in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> �OWNER� AND �MODERATORS� OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER
> INTANGIBLE LOSSES (EVEN IF THE  �OWNER� AND �MODERATORS� OF DIGITAL
> BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF
> SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
> THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO
> OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO
> GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
> YAHOO! GROUPS LINKS
>  Visit your group "DigitalBlackandWhiteThePrint" on the web.
>  To unsubscribe from this group, send an email to:
>  DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
>  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2005-09-17 by Steve Kale
I understood good practice to be at least always use a clean factor of the
print resolution ie 2880/4=720, 2880/5=576, 2880/6=480, 2880/8=360,
2880/9=320, 2880/10=288.  The 300 simply came about as a result of the old
2x150lpi (as Bob Frost noted in an earlier post).
> From: Steve Gledhill <stephengledhill@...>
> Date: Sat, 17 Sep 2005 13:08:42 -0000
> Subject: [Digital BW] 300ppi vs 360ppi
> perpendicular to the image edge ­ i.e. it slopes or is angled across
> ­ and once noticed, it was obvious.  It's not some micro effect that
> file sent to two different printers ­ a 2100 and a 4800.
> Steve Gledhill
2005-09-17 by hogarth@snappydsl.net
My understanding is that the two are not related.
The output resolution, say 300 dpi, that you send the printer will be
uprezed or downrezed by the driver to 360 dpi.
The print rez, say 1440, really controls how many ink dots the driver
uses to create each pixel. And this is why the driver must resize your
incoming 300 dpi data stream to 360 dpi - so that it can easily handle
the math to represent the individual pixels, and the dither pattern it
uses to "flow the tones" from one pixel to the next.
Most RIPs, being considerably larger and more sophisticated programs,
don't need the resizing step. So I'm told.
I could be wrong though.
Bruce Watson
RE: [Digital BW] 300ppi vs 360ppi
2005-09-17 by Paul D. DeRocco
> From: Steve Kale
The stock Epson driver resamples everything to 720ppi for the desktop
models, 360ppi for the wide format models, and then dithers to the higher
dpi value. If you want complete control over the resampling, and don't want
to trust the Epson driver not to introduce aliasing, use an integral
subdivision of those numbers.
The old drivers used "nearest neighbor" for resampling, which was asking for
trouble. However, the most recent drivers include an edge smoothing option,
to eliminate aliasing when it upsamples. I haven't tested it to see how it
compares to other manual resampling techniques.
2005-09-17 by Bob Frost
Steve,
I haven't printed at some of those resolutions, but I always understood that
the numbers should be factors of 720ppi, the ppi that the printer uses for
printing, not the dpi. So 360ppi is OK, as is 240 and 180, but not 480 or
576. Easy to confirm by printing a set of black and white 1 pixel lines and
looking for the aliasing patterns. Many give you a lovely 'tartan' like
print (for those of you who know of Scotland).
Bob Frost.
2005-09-17 by Lotusm50
What I don't get is, does this mean that you can really optimally
print only 4 or 5 different sized prints for a given file.  Say with a
given file you can print an 8x10 print at 720 ppi.  Then say you want
to crop it differently leaving the file smaller by 15%.  Does that
mean you can't print the file at the 8x10 size because it would no
longer print at 720 ppi (or 360 ppi)?  Or odes the printer dricer
automatically re-size file sent ot the printer to the optimal
resultion for the printer.  It would seem quite odd to me that a
proffessional quality printer would be so limited in effective print
sizes.  Or is the quality difference between printing at 360 ppi and
320 ppi in fact almost impossible to see?  I don't think I ever try to
print at 360 or 720 ppi.  I take the file as it comes and if I want an
8x10 or an 11x14 I print it to that size (using 1160 with CIS &
Piezotone inks).  I never really see any problems with the resolution,
detail, or quality of the print.
What shouls I be noticing in a print not printed at a multiple of 720
ppi that I am not seeing?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Frost"
<bob@f...> wrote:
> Steve,
understood that
uses for
480 or
lines and
> Bob Frost.
> From: "Steve Kale" <stevekale@b...>
of the
the old
2005-09-17 by Bert Katzung
Hi Lotusm50:
I think you're making things much more complicated than they really are.
Remember that Photoshop and any other competent image processing program can
resize to any desired size and resolution (within the limits of available
memory). I work in  Photoshop and I simply set the size to the dimensions I
want and the resolution to the appropriate level (I had been using 300 with
no problems but 360 seems to have some advantage) and let the program
resample the image to match. In other words say I want 4.75 inches x 6.8
inches final print size (which I did recently for replacing a faded "5x7").
I plug one of the dimensions (4.75) in to the Image/Image Size dialog box
with 360 dpi as the resolution and check Constrain Proportions and Resample
Image: bicubic and let it run.
There are lots of options, of course, but that's the basic drill.
Hope this helps...
Bert
katzung1@...
www.astronomy-images.com
www.visionlightgallery.com/katzung/
Sent: Saturday, September 17, 2005 10:54 AM
Subject: Re: [Digital BW] 300ppi vs 360ppi
<bob@f...> wrote:
> Steve,
understood that
uses for
480 or
lines and
> Bob Frost.
Lotusm50,
I think the problem that I described to start this thread is only
apparent when your chosen ppi is some simple fraction of 360ppi - as
is 300ppi.  When the ppi is some odd number like 327ppi or 941 ppi or
perhaps as suggested earlier in this thread 301ppi or 299ppi then the
maths involved in the driver resampling to the native printer
resolution (360 ppi / 720 ppi / ...) doesn't give rise to the 'jagged'
effects that I described.
So, I believe the answer to your question is "no".  You can print any
file at any ppi without the jaggies problem - as long as your file
isn't a simple fraction of 360ppi - like the 300ppi where I found my
problem.  You, like many people, may have never seen this problem, but
those who print 300ppi files should look carefully - you my find a
step improvement in your printing by the simple action of resampling
to 360ppi before printing.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Lotusm50"
> <bob@f...> wrote:
> > Steve,
> understood that
> uses for
> 480 or
> lines and
like
> > Bob Frost.
> of the
> the old
Re: 300ppi vs 360ppi
2005-09-18 by Roy Harrington
I think its very much like a moire pattern or aliasing.  All the Epson drivers
effectively resample the image to 360 or 720 ppi.  With a straight diagonal
line its likely you would see a jagged pattern of aliasing.  Exact multiples of
360 or completely odd numbers would be probably be all right.  The 301
may be slightly jagged but won't have a pattern in it so your eye doesn't
object to it.
Roy
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Gledhill"
<stephengledhill@y...> wrote:
> Lotusm50,
> Steve
> > <bob@f...> wrote:
> > > Steve,
> > understood that
> > uses for
> > 480 or
> > lines and
> like
> > > Bob Frost.
> > of the
> > the old
