Re: [Digital BW] Framing - Any views on FrameCo products?
2005-09-19 by Walt Mucha
>I am thinking about buying some framing equipment. Any views re FrameCo equipment? For >example, the 1060B mat cutter vs, say, the Logan Simplex Plus 750 which is much more >expensive. What about joiners and saws. I hate to give you the bad news, but, there's no cheap way to do what you want to do and get frameshop quality. You will need a good chopper (not a chop saw) an underpinner, corner vises and a quality mat cutter. The Logan PRO mat cutters are barely adequite. I looked at the frameco stuff and wouldn't recommend it. If you got around $7500 - $10000 then you can get professional results without much sweat. If you're just going to do a few pieces now and then and aren't looking for frameshop quality then you can get by with a chop saw, brad nailer, corner vises and a cheap mat cutter. Unless you're really good with wood, you probably could get better looking frames at Walmart. Regards, Walt http://www.kauaiphotos.biz
