i1 & Pulse Comparison
2005-09-19 by joshhackney
Folks, I have been preparing to purchase a spectrophotometer - partly for the purpose of creating curves for QTR. A big question for me is i1 or Pulse. I ran across the following on Rob Galbreth's forum and found it helpful: "I have seen and played with the Pulse. Monaco obviously looked long and hard at all the nagging quirks of the Eye-One. The Pulse is well thought out, even including a flashing disco light. Measuring a strip of patches is fast and, compared to the Eye-One, painless. You can even measure a chart with the Pulse untethered. It does not make emissive measurements, hence the need for the Optix XR puck. I have two concerns about the Pulse. The first is measurement resolution. X-Rites instruments measure color at 20nm intervals. GretagMacbeth's kit uses 10nm intervals. The Pulse interpolates to 10nm to make compatible files. Earlier X-Rite products, including the DTP-41, were hampered by the reduced resolution. I found the 41 less adept at handling metameric pigments than were Gretag's products. Monaco claims their data is clean enough that there should be no difference. I am having a chart measured by Monaco on the DTP-70 and will compare to what I measure on a Spectroscan. Whether splitting this particular hair has any real significance, I do not yet know. Concern 2: Monaco's software does not automatically detect and compensate for optical brighteners with the same ability as does GMB's. This means measurements of papers with strong optical brighteners are off. The instrument reads the blue cast to the paper, and the profiles have a corresponding yellow cast in highlights. That's ugly. If you use Monaco's software, the UV filter is a must for papers with brighteners. That's too bad, as it degrades accuracy in blues. GMB has yet to announce plans regarding support for the Pulse or DTP-70, so it is uncertain if you can use GMB software with the new Monaco stuff. There appears to be a growing spat between the companies. Monaco has never supported GMB's iCColor, nor has GMB supported the XR/DTP-94." there was a response with the following. "I share Ethan's concerns regarding the spectral resolution of the Pulse. The Eye One reports every 10nm from 380nm to 730nm, but it actually measures with 3nm resolution. On the other hand, the Pulse reports every 10nm from 400nm to 700nm, but it actually only measures with 20nm resolution and interpolates to create the additional points. The Eye One not only has a greater spectral range at both ends, but measures with three times the spectral resolution it actually reports. On the other hand, the Pulse reports twice the resolution it actually measures. The Eye One has six times the real resolution of the Pulse and 17% greater spectral range. Making an instrument with more native resolution than it reports is simply good measurement technique. Using a UV filter is a workable solution to dealing with brighteners, but it is dumbing down the measurement to brute force deal with the issue. Much better is to look at the real data and have software smart enought to competently deal with the brigheners." The full thread can be found at: http://forums.robgalbraith.com/showflat.php?Cat=&Number=286998 Both devices are reviewed at the following link http://www.gnyman.com/ComparisonPulseEyeOne.htm This review shows that profiles from both devices are very similar. Does anyone on this forum have any thoughts on this data? If anyone has come across any other information on these devices I'd be interested to see it. Good luck. Josh
