OT: Need help on upgrading monitor CRT to LCD
2005-09-27 by Scott Jones
Greetings:
Sorry for the OT post, but this is my main printing community and
this question does pertain to my ability to print.
I currently use a very old 17" Compaq CRT calibrated by Monaco. I
wish to change to an LCD and am wondering if Dell's UltraSharp 17"
LCD monitors will be of sufficient quality for my B&W and color printing
on my R2400 printer. I will be calibrating with the Monaco. Will it
be good enough in the shadows and have good enough color qualities to
do good quality photographic printing?
I use Windows XP and have a video card that can handle both analog
and digital output. Thanks for helping me make this transition...
Scott
RE: [Digital BW] OT: Need help on upgrading monitor CRT to LCD
2005-09-28 by Ken Carney
Scott,
My biggest problem in transiting to an LCD for b&w was that the thing was so
dang bright and constrasty (get the sunglasses).  Life became easier when I
cranked down the brightness considerably and turned up the room lights, and
then calibrated (OptiCal Pro).  No problem then relating shadow detail to
the print (using ImagePrint RIP).  With color it is the same, but there I
can soft-proof and get it the first time or maybe second at most.
  --Ken
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On
> Behalf Of Scott Jones
> Sent: Tuesday, September 27, 2005 12:00 AM
> Subject: [Digital BW] OT: Need help on upgrading monitor CRT to LCD
> Greetings:
> and this question does pertain to my ability to print.
> Monaco. I wish to change to an LCD and am wondering if Dell's
> UltraSharp 17"
> color printing on my R2400 printer. I will be calibrating
> with the Monaco. Will it be good enough in the shadows and
> have good enough color qualities to do good quality
> analog and digital output. Thanks for helping me make this
> transition...
> Scott
2005-09-28 by Scott Jones
Thanks, that was helpful. Can any of our users comment specifically on
the Dell UltraSharp monitors and whether they will be sufficient? Some
of the reports I have read suggest that the panels are the same as
those in the Apple's. Anybody using them? I need some encouragement
before making the leap. Thanks in advance.
Scott
Re: [Digital BW] OT: Need help on upgrading monitor CRT to LCD
2005-09-28 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Scott Jones"
on
Some
> Scott
How much does it cost? Samsung has been a leader in LCD technology,
and ultimately, they may be the real manufacturer of the panels for
the apple displays, but I'm not entirely sure about that. So a
Samsung Syncmaster might be a good option. NEC/Mitsubishi multisync
LCDs might also be a good option. Whatever you get, you really want
one of the multisync rate monitors, they all seem to be a higher
class of display.
2005-09-28 by Peter Marquis-Kyle
Scott, there's a forum thread on this subject on Rob Galbraith's site
that makes interesting reading:
http://forums.robgalbraith.com/showthreaded.php?Cat=0&Number=350263&an=&page=0&vc=1
After some discussion back and forth, the bottom line seems to be that
the Dell panel is fine, the control circuitry is not, which makes the
Dell monitor less useful than the Apple Cinema Display (for critical
photo work, that is). I have not used one of these Dell monitors, I'm
just reporting what I have read. My pair of Trinitron CRT monitors is
getting old, so I have a lively interest though....
Peter Marquis-Kyle
2005-09-28 by wwodets
Ken and Scott-
If you have an LCD with separate brightness, contrast and backlight
control you can calibrate the monitor for any gamma and temp at any
luminance level.  Although a luminance of 100-140 cd/m2 is considered
standard, I calibrate mine at about 40 and get a luminance that is
very close to that of a paper print at 450 lux.  This makes soft
proofing much more accurate.  The i1 actually measures the luminance
level for you, which makes the setting repeatable.  Incidentally on
my Sony LCD, this is a backlight level of about 30%.
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ken Carney"
<kcarney1@c...> wrote:
> Scott,
thing was so
easier when I
lights, and
detail to
there I
>   --Ken
LCD
> > Greetings:
> > UltraSharp 17"
> > transition...
> > Scott
2005-09-28 by Sam McCandless
>Scott
The Apple conjecture is plausible since it owns part of Samsung and
Dell sells at least some Samsung monitors as "Dell" monitors. But I
doubt whether it's true because I've never heard it said among Mac
users, who have however been buying Dell's discounted 21- and 24-inch
LCD's. Bare Feats reviewed the 24-inch one, vs. Apple's 23-inch
display, at <http://www.barefeats.com/lcd.html>.
I looked at Dell's smaller LCD's because I'd like one which rotates
into the portrait orientation for more convenient use on my crowded
desktop as a Photoshop "palette monitor". No luck, at Dell or
elsewhere, so I got a 17" Dell CRT made by Samsung (I asked). It's ok
for palettes (and e-mail, etc.), but, from ordering to delivery, I
got the worst service from Dell that I've ever gotten anywhere in
many years of using both WinTel and Apple boxes.
At the same time, I was shopping for a new rotating/pivoting
1280x1024 19-inch LCD display for full-size 14 x 11 _and_ 11 x 14
images. EIZO has one in their "Graphics Monitors" line which I like
so much that I decided to see what else I can postpone so I can
afford it. But I've since decided that their 20-inch L887 is a much
better value. Incidentally, EIZO still has monochrome displays
(intended for medical use), including an 18-inch one, listed on
<http://radiforce.com/en/products/index.html>.
The best prices might be at <http://www.monitoroutlet.com/>, and I
think the best advice - but maybe not for Dell displays specifically
- might be at <http://www.chromix.com/>.
Sam
