New Versions of QuadToneRIP both Mac and PC and New Website
2005-09-28 by Roy Harrington
Version 2.3.1 of QuadToneRIP is now released for both Mac and PC. A brand new website especially for QuadToneRIP makes its debut! See http://www.quadtonerip.com It's operational and there's more to come. The 2.3.1 version is available on both the old download sites (for a while) and the new site. The major additions are: new printers, R2400, 4800, (7800 & 9800 preliminary). Many new profiles for new B&W inksets: Neutral K7 for 2200, 4000, 7600, 9600, (NK6 for 7500 preliminary, see notes in folder). QuadBlack for R200, 2200 One more thing: I separated the profiles for different inksets so they are not all together. The main organizational change is to add the ink type to the printer names for the non-epson inks. So 2200 with NK7 inks will be Quad2200-NK7. UT7 inks are under Quad2200-UT7 etc. If you use the install scripts that I have you can do your own inksets easily by renaming the Install script. So Install4000-CSNK would give you a Quad4000-CSNK printer. ------------- Updates for QTR-Create-ICC tool: It now supports color softproofing -- works but highlights are slighty too saturated fixes are in progress. Supports a more general data input file. Anything columnar, looks for column headings of: GRAY L, LAB, LAB_L, A, LAB_A, B, LAB_B D, DENSITY, V, VISUAL Try it on your data file are see if it works. Let me know of any that don't. QTR-Linearize-Data accepts same data files. Roy
