Need information regarding Epson 1270 and UT FS ink
2005-10-13 by espenlodden
Hello,
I've been searching this forum for information about the Epson 1270
used with the MIS UT FS inks, but have found little. I am quite new to
BW photography and printing and have been using an Epson C84 with the
EZW inks with good results. However I really miss the opportunity to
print on larger media. I was recently on the verge of buying a new
Epson 2400, but decided against since it is quite expensive and also
have more expensive inks than the MIS inks. I am now considering
buying a used 1270 instead and wait for the 2400 to come down in
price. However, I'd like som input from anyone with experience from
this printer.
* How is the quality compared to the BW quality one can achieve with
the 2400?
* I've seen some threads regarding clogging problems when refilling
cartridges on the 1270. Is this a common problem?
* Will MIS continue producing inks and catridges for this printer for
the next couple of years at least?
* Will there be a big difference in quality (or any other issues) if I
should decide to buy a new 1290s instead? (more than twice the price)
I hope you can help me. I've already learned a lot from this forum,
and the amount of information gathered here is nothing short of
impressive!
Best Regards
Espen Lodden
RE: [Digital BW] Need information regarding Epson 1270 and UT FS ink
2005-10-13 by Paul Roark
Espen,
> used with the MIS UT FS inks, ...
See my Readme file at:
http://home1.gte.net/res09aij/1270-FS-Readme.htm
> the 2400?
If the 1270 is working perfectly, and the curves fit the printer and inkset
well, the 1270 with FS inks can visually match the 2400.  I'd far rather
have a 2400, however.  It's a question of money.  If a 1270 is given to you
it may be worth trying.
I can't quantify the degree of the problems.
The clear carts seem to be the way to go, but I'm not thrilled with any of
those older carts.
The individual C86 - 2400 cart design has become a much more reliable
approach, in my view.  Consider, for example, the lack of need for precisely
matching the spacing between the printer inlets and cart outlets.  Those 2
production variables almost guarantee fit problems, including, perhaps,
allowing air to leak into the head, causing almost incurable bubbles that
look like clogs.
Probably, but I'm not MIS.  I won't spend more time on old printers.
Hope this helps.
Re: Need information regarding Epson 1270 and UT FS ink
2005-10-13 by kenstrain2000
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "espenlodden"
> this printer.
I got a couple on ebay for very little money (but working and with
EPSON cartridges to allow tests).  This while also using a 1290 and
knowing the many similarities and few differences.
> the 2400?
No idea - probably the difference in speed is larger though. Don't be
in a hurry with 1270s. But I'm patient and never quite felt ready to
buy one or two more expensive printers.  There is always something
else to do, and 3 printers in parallel get through enough paper anyway.
Same cartriges as 1290s, inks work for many printers.
I hope much more than twice the price.  1270 should be very cheap.
Ken
Re: [Digital BW] Need information regarding Epson 1270 and UT FS ink
2005-10-14 by espenlodden
Thank you very much for the quick reply.
I saw some prints from the 2400 yesterday, and they were really
stunning. Sooner or later I will buy a 2400 for color printing,
however I'm still wondering whether an extra dedicated printer for BW
printing could be viable in order to cut ink costs. In that case I had
hoped to save some money by buying an older printer. I can propably
get a 1270 for about $100-150 here in Norway.
Espen
<paul.roark@v...> wrote:
> Espen,
1270
with
> > the 2400?
inkset
rather
to you
refilling
any of
> those older carts.
reliable
precisely
Those 2
perhaps,
that
> look like clogs.
for
> Hope this helps.
> Paul
> www.PaulRoark.com
Yes, propably the difference is bigger. The problem in Norway is
actually finding a printer for sale.
Speed is not a big issue for me. Is there any reason to choose a 1290s
over the 1270? The difference in price is about $200-300
Espen
2005-10-14 by kenstrain2000
The driver for the 1270 has 1440 as the highest resolution setting. At
it happens I never use higher on my 1290. However, that there are
several recommendations to use 2880, so there may be some
circumstances where it would be useful to have a 1290.  I just don't
know them.  I'm always a bit sceptical when, in either printers or
scanners, the resolution in one dimension exceeds that in the
orthogonal dimension by more than a factor of two.  I doubt that it is
meaningful to have 2880x720 "resolution".  It probably puts down more
ink than 1440x720.  I've never seen a lack of ink with my 1270s at 1440.
Perhaps the 1270 is disappearing by now.  I see none on UK ebay today,
nor even worldwide, so perhaps my suggestion is not very helpful.
Ken
