Fw: [Digital BW] Digest Number 3476
2005-10-17 by Ben Ong
> > Re: best of the best what to buy? > > Hi palladiumprinter! Ohhhhhh man I wish I was you :) Well if money wasn't > an issue for me, this would be my set up: > > #1 - Epson 4000 Printer (prints A2+ sheets) > > #2 - Piezotone inks (there are 4 sets of inks which are made up of 4 inks > each). (well 3 inks that share the same black if you want to be fussy, but > lets not get confused) Anyway the point is you can have a tone on either > side as the printer holds eight cartridges. I would choose "selenium" for > one side as it's the most neutral, and then the lovely "warm tone" set. > The other two are"cool neutral" and "carbon sepia" which are also sooooo > good. So what ever you use most. Or if $$$ really wasn't an issue I would > have all four tones and just change tones as you want to use them; > expensive though as you need to flush out the inks in the lines already. > Or you could just but 2 Epson 4000 printers! Hmmmmm yes. > > #3- Studio Print 11 RIP which is a state of the art piece of software that > runs the printer and the inks. The main reason for it in this set-up is > you need to tell the printer to only use 4 inks at a time. For example > "use only the 4 selenium tones inks" etc. Some people use the one main > black I was talking about before, for both sets which is pointless is you > have this software, just load two "portfolio" blacks and use one for each > "tone". Oh and the software has a densitometer which I'm sure you'll > appreciate as a "palladium printer". > > > And well that's about it. Don't forget to use great paper (this system > only works on matte paper), and of corse there is no point in having this > set up if you don't also have a great scanner two get all those lovely > tones in the first place - which I'm sure are already in your negs! :) > You will match any wet print with this set up (remember to compare using > similar papers though, there's no point saying my Oriental Siegel prints > are still better. Compare a Matte Fibrebase paper, not satin, MATTE, and > you will be amazed). > > Well it's been nice dreaming. Have fun. I hate you ( haa haa just kidding. > good luck) > > Benny
