Right, go to your color settings and see what behavior you have set
for color management policies, then mismatches "ask when pasting".
T
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington"
<roy@h...> wrote:
> Paul,
> It sounds like what you are seeing is a change in profile.
Basically like
> doing an Assign profile. The untagged file is treated as having the
profile you
> have selected as Gray Working Space in Color Settings. So you are
seeing the values in
> the file as the embedded ICC, but when you paste those values into
the untagged
> file you are then seeing them as the default gray space. What you
see on the
> display is ALWAYS based on a profile -- there is no disable of color
management on
> the screen.
> Roy
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
<paul.roark@v...>
> wrote:
> > When I past a file with an embedded ICC onto an untagged gray file
the view
> > becomes unusually dark - darker than it would be as an untagged
gray file.
> > Why is this?
> > Paul
> > www.PaulRoark.com <http://www.paulroark.com/>
