Re: [Digital BW] Re: 1280 / MIS SPONGELESS CART PROBLEM
2005-11-28 by Edward Wiseman
MY THX to Ken,Ken and John for your repsonses....
I've contacted MIS this AM, and they are sending me a new empty color cart
and a color cleaning cart to try, along with the "newer" filler plugs with
the "grabbable" top, not requiring a pin..According to them, one of two
possibilities occurred:
1.0  The carts were filled too near the top.... They should ONLY be filled
1/4" from the top of each cartridge..
                      OR
2.0 The OLDER plugs became porous from repeated pin pricks..
I'll reserve an further comment until AFTER I get my heads
UNCLOGGED!....I'll re-post at that time...
Eddie Wiseman
Sent: Monday, November 28, 2005 2:37 AM
Subject: [Digital BW] Re: 1280 / MIS SPONGELESS CART PROBLEM
> The second fill, I used a straight pin
> to help remove the plugs. This procedure had been mentioned by a
> couple posters here. But I saw a problem with that. The pin can go
> right into the plug, into the hollow center of the plug, thus
> creating an air channel, and possible leaks. I feel it was a learning
> error, and I could probably carefully use the pin without it piercing
> into the hollow portion of the plug. But still I ordered 10 extra
> plugs the other day, and will learn to refine the procedure.
MIS supply 2 types of plug (at least) one is a solid cylinder with a
small bump at one end, these go flush into the cart when fitted.  The
pin trick is appopriate for these.  The other design is T-shaped or
hat shaped: there is a hollow cylinder, that goes into the cart, plus
a cap that is larger than the  hole in the cart. The pin trick is not
appropriate and should not be needed for these - lift the cap part and
pull.
I suspect the main problem is quality control of the holes drilled in
the tops of the carts (some are definitely too large to give a tight
fit).
Perhaps some printers are more susceptible to leaks - mine were all
very old.  I had ink leaking around the cartridge nozzles on the
printhead (and probably also through the printhead, but it was hard to
tell).
Ken
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
