comparing black inks
2005-12-12 by finnkrogvig
Hello all
I have recently started printing B&W using Piezography and PiezoTone
inks.
Since I joined this group I have not seen any "talk" about PiezoTone
inks, but a lot about MIS UT inks. Is no one else in this group using
PiezoTone inks ?
-And how does MIS inks compare to PiezoTone? IE How does the Dmax of
Eboni Black compare to Portfolio Black? Has anybody any experience with
this?
FinnK
RE: [Digital BW] comparing black inks
2005-12-12 by Paul Roark
Eboni is close to Museum black.  Portfolio black has some dye added to it,
which gives it a better dmax but less longevity.
The MIS UT-FS and UT-FSN inks use the PiezoBW ink densities.  The original
FS and FSN inks were designed for the Piezo driver (which I started with).
So, the MIS UT-FS and FSN are about the same as the PiezoTones.
C84/EZ nicking corners
2005-12-12 by Kip Babington
I'm in the midst of printing my Christmas books (about 750 8x8 prints
from 200 or so different images, bound into 9 separate volumes for
various family members) using my C84 with EZ inks - as I did last year.
While not the fastest printer around, I can order up the number of
copies I need of a particular print (not every volume gets the same
images) and do something else for a while - couldn't do that in the
darkroom :-) .  (I've been doing this process for about 20 years - when
I did it "wet" I had to start well before Thanksgiving, and spent many a
night standing up in the dark into the wee hours of the morning sloshing
paper through chemicals.  Can't imagine ever going back to that.)
The images are printed landscape at the right end of 8.5x11 paper, which
I eventually trim down to 8.5x9 to have a binding edge on the left.
Anyway, yesterday the printer began to "nick" the top right corner of
the paper at the end of the print during the last 20-30 passes (the left
side of the printer, away from the head parking station.)  This ended up
knocking the paper slightly out of alignment for the final passes,
curling the corner and leaving a bunch of black ink there, effectively
ruining the print.  I have enough room on the page that I have shifted
the image about an inch away from the end of the paper, so the image
finishes printing before the end of the paper comes out of the rear
rollers, but now I'm going to have to make two cuts on each page instead
of one.
Anybody know if this "nicking" is just an adjustment, or is it a sign
that the printer is wearing out?  (I wore one out last year that had
gone about 1500 prints but was still within the warranty period.  Epson
seemed astounded that I had used one of these things that much.)  I love
the convenience of the C84/EZ combination with the CFS, and assume I
might just have to replace this one with the current equivalent - is
that the C86 or the C88?  Anybody know if the CFS would just transfer
over to one of the newer printers, or would I need a new one?
Thanks for any experience and/or advice.
Kip
Re: [Digital BW] C84/EZ nicking corners
2005-12-12 by Matti Koskinen
I had the same thing with my C84. It was under warranty and Epson
checked it saying nothing was wrong. I came into conclusion it was the
paper batch. It just curled when off of the guides and caused similar
symptoms as you describe. Then with a new papers (I used Epson HWM) it
worked ok, until the heads clogged and tossed it.
-matti
Re: [Digital BW] comparing black inks
2005-12-12 by Peter Marshall
Yes, I'm using Peizotones - and have been since they replaced the
earlier Piezo inks. Really there isn't anything to say about them. I
switch on the printer, follow the instructions and print. And there is a
PeizoBW group, though very few messages there.
I use the Museum black and haven't any problems with the density on
Hahnemuhle Photorag and similar papers.
But I don't own a densitometer:-) I've yet to see anyone else produce a
print that makes me want the bother of trying any other inks on
Photorag, though I have made the occasional black and white on glossy
and lustre surfaces with the Epson 2400.
The MIS inks are certainly cheaper than Piezotones, but given the cost
of ink is a fairly small % of the print price I'm not too worried about it.
Peter Marshall
petermarshall@...
My London Diary	              http://mylondondiary.co.uk/
London's Industrial Heritage: http://petermarshallphotos.co.uk/
The Buildings of London etc:  http://londonphotographs.co.uk/
and elsewhere......
finnkrogvig wrote:
>Hello all
>inks.
>PiezoTone inks ?
>this?
>FinnK
>Please visit the Group Homepage to check the Files, and other resources as they are often being updated.
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page.
>Please follow these basic guidelines:
>- As threads develop, trim off excess portions of earlier messages to keep them short.
>- Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice.
>- Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership.
>- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
>Yahoo! Groups Links
Re: C84/EZ nicking corners
2005-12-12 by mkirschner
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Kip Babington
sign
Kip,
What thickness paper are you using? My C86 gets fussy or downright
uncooperative with papers much thicker than 11 mil or so. I've had
damaged paper/ink "spatter" but not in the exact way you described.
The symptoms developed after several sheets of Hanhnemuhle Photo Rag
fed/printed just fine. Going to a somewhat reduced thickness paper
helped but still led to damaged paper. So now I stick to 11mil or so
papers, for the sake of the print as well as printer longevity (I do
miss using the thicker papers though).
On a separate tangent: How are you binding the photo books? I've
been wanting to get into this. Any references/tips for getting
started? Are you using all archival materials?
Mitch
Re: [Digital BW] Re: C84/EZ nicking corners
Mitch, I have been using EEM, whose box lists it as a 10 mil paper.  I
know it is not "archival" but when I go through 800 sheets at a time I
am not really prepared to pay what the truly archival papers cost.
These prints end up being looked at on Christmas day and perhaps once or
twice more, and then they get put on shelves for the duration.  Any
deterioration will be due almost entirely to the nature of the inks and
the paper, as environmental causes will only be able to affect the page
edges.  For what these books are, that's good enough.
For binding I use the GBC plastic combs, the ones that need a line of
rectangular holes on the edge of the paper.  I use mat board, cut about
1/2 inch larger than the pages, for covers.  I started this process
about 20 years ago, and that was the binding system that my law firm
used for office purposes, and I just used it because it was available.
After a number of years when I spent Christmas morning down at the
office binding up books to be given away at family celebrations that
evening, I finally bought a punch and binding machine for home, and have
just kept using it.  It does not make a particularly elegant book, and
if the books get too thick (which mine do, at least for the
grandparents) the combs can want to stretch a bit.  But it is an easy
and effective system that I can use in my (old) darkroom to organize and
maintain a large number of photos each year for different family members.
Kip
mkirschner wrote:
>Kip,
>Mitch
2005-12-13 by mkirschner
of
about
Kip,
Thanks for the ideas. I too produce photos for my children's
grandparents and other relatives. It's too late (and there's not
enough hours in the day with two very young children in the house) to
do something this year, but next year I'd like to put something
together. I admire your dedication. Family photo production is
literally a labor of love (or an inescapable obligation, or both :).
If your printer has an incurable problem, I assume you're aware that
the latest/best "EZ" system to consider is the Epson R220, which
according to Paul Roark (if I remember correctly from a recent post)
is available for about $55 on eBay. When my B&W-dedicated C86 dies (I
give it a year despite continuous TLC), that will be my next B&W
machine.
Mitch
2005-12-13 by Kip Babington
Thanks for the word on the R220 printer, Mitch.  Once I got my C84 up
and running I sort of stopped keeping track of what was going on in the
printer world.  Epson changes printer models so fast, and I didn't need
a replacement, that I just stopped paying attention.  I actually have a
"spare" C84 that I keep Epson color carts in, and use as an occasional
convenience printer (my "regular" color printer is a Canon S900 for
which I reload cartridges - a very fast printer and very refill-friendly
cartridges.)  There was a time when the C84s were cheaper than the price
of the ink cartridges that came with them (and one 12 hour stretch when
you could get one from Office Depot for under $10 after all the
applicable rebates) so I bought two for about $70 total.  I figure I can
move the CIS over to the color printer, purge and be back in business in
an hour or so if it comes to that.
Do you know if the R220 is any "tougher" printer than the C84 series?
At the price I would assume not.  My impression is that the C84 design
life is no more than a few thousand prints.
Thanks again for the thoughts.
Kip
series?
design
Kip,
I don't know if the R220 is any tougher than the C8x series, but I
doubt it. However, it does have the feature of enabling you to print
on CD's and DVD's (you need special optical media which is designed
for this kind of printing).
As far as B&W printing goes, the R220 is a 6-ink printer, so the EZ
prints are supposed to be a bit smoother (though my C86 prints are
darn smooth). Its main appeal from my standpoint is that it
supposedly does better black-only printing than the C8x printers,
and you have more flexibility with the inkset. More info from Paul
Roark here:
http://home1.gte.net/res09aij/
I also recall seeing a couple of recent R220-related posts on this
list.
I currently have two C86's, both using refillable carts. One has EZ
inks and is dedicated to B&W printing. The other has MIS PRO inks
(pigmented). I'm quite satisfied with both. I also have an
inexpensive Canon Pixma printer, which makes lovely color prints,
but alas they're not archival.
Mitch
Epson changes printer models so fast...
2005-12-13 by koloshor
Kip,
I'm amazed that you feel this way. Epson is the slowest changing, most
stable of all the printer manufacturers. Have you ever looked at Canon
or HP? They both keep a model in the lineup for about a year. Epson
seems to get about 3 years out of a model.
That's one of the biggest reasons that the GIMP print team focuses so
heavily on Epsons, because of Epson stability.
Re: [Digital BW] Epson changes printer models so fast...
2005-12-13 by Peter Marshall
Here in the UK, the Epson 1160 is still being sold. Not sure when I
bought my first (I own 3 as well as an R2400) but it was well over 3
years back. Still a good printer for quadtone black and white.
Peter Marshall
petermarshall@...
and elsewhere......
>Kip,
>Yahoo! Groups Links
2005-12-14 by Kip Babington
I have not looked at Canon or HP lineups in years, although I do have an
HP multifunction machine and 2 Canon 6-ink printers, all of which are
older than my Epsons.  My impression of Epson is based on my very narrow
experience with the C84, which I first bought in the summer of '04.  In
the intervening 18 months, the C84 was replaced by the C86 which I
gather has been replaced by the C88.  That struck me as a lot of
changing in not a lot of time.  But maybe others change even faster.
Kip
>Kip,
