spraying technique
spraying technique
2005-12-16 by Allan Chen
Hi all,
	I am hoping someone can help me with archival spraying technique.
	I did a quick search on this and found several posts on how many times
to spray, how fast to go, etc.  However, I'm having an issue with the
premier art spray where it runs out as you spray.  I hold the can
parallel to the print, so that the nozzle is straight down.  After a
while, the nozzle runs dry because, presumably, the liquid is sitting
below the feeder tube running into the can.  This not only causes a few
spurts as it peeters out, but it also means I have to stop halfway
through a print, wait a bit, then start spraying again.
	Is there a better way to do this?  Should I hold the can upright  and
kind of long-range it to the print?
allan
http://allan.kaiyen.com
http://photos.kaiyen.com
Re: spraying technique
2005-12-17 by koloshor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Allan Chen
<allan@k...> wrote:
> Hi all,
No, that will cause frosting.
Tape a big piece of cardboard to the wall. Tape the print to the
cardboard with double sided tape. If you do multiple prints you can
walk the spray back and fourth to get it very even.
