LCD calibration; which white point setting?
2005-12-17 by marcsienicki
Hi all. This is a follow-up question to my earlier posting on luminance level calibration. With regards to white point, I've always left it at 6500 but wonder if I should change it to a 5000K since I view my test prints under a D50 light source while working on them. Thanks for helping me climb the learning curve, Marc.
2005-12-17 by Steve Kale
Marc You may find Bruce Fraser's book "Real World Color Management" useful. Steve
> From: marcsienicki <marcsienicki@...> > Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Date: Sat, 17 Dec 2005 13:59:30 -0000 > To: <DigitalBlackandWhiteThePrint@yahoogroups.com> > Subject: [Digital BW] LCD calibration; which white point setting? > > Hi all. This is a follow-up question to my earlier posting on luminance level > calibration. > With regards to white point, I've always left it at 6500 but wonder if I > should change it to a > 5000K since I view my test prints under a D50 light source while working on > them. > Thanks for helping me climb the learning curve, Marc. >
2005-12-17 by Louis Dina
Hi Marc. For over a year, I really tried to get 6500K to work for me. I wanted, if possible, to calibrate my monitors to the Windows and WWW standard, since that would make life easier all around. Some people seem happy with 6500K for their personal work, but it never gave me what I would call an acceptable monitor to print match with good custom profiles. At 6500K, the monitor is a bluish white, so I was always adding more yellow to compensate. My prints always looked much yellower than my monitor (using D50 viewing lights and the same brightness as my monitor). I knew my profiles were good. I know the eye adapts, but mine never could make that big a leap. So, I spent months experimentation with color temp, gamma, luminance, etc. I have found that when set to 6500K, neutrals on screen are very blueish, both to the eye and measured with a spectrophotometer. 5000K is spectrally neutral, and also happens to be about the color temp of most printing papers. One of the whitest papers I ever use is Epson Premium Glossy, which measures about 5200K. The rest are warmer, in the 4800 to 5000K range. To complicate matters, monitors vary in quality and range. Most have a definite "sweet spot" where they perform the best. So for me, ideally 5000K is the best point. But lower temperatures, especially on lesser quality monitors, can reduce gamut, smoothness, etc. If you stay within the sweet spot of your monitor, the loss is minimal, and in my opinion well worth a good monitor to print match. Once you step out of the sweet spot, you begin to lose too much. For this reason, I calibrate my monitors to somewhere between 5000K and 5500K, depending on the actual monitor. Once I did this, my monitor to print match became nearly perfect. The same file will now appear less blue (more yellow) on screen and the prints match nicely. Contrast level also varies quite a bit from one monitor to the next. My LCD gives me the correct distribution of tones when set to 2.2, but my CRT at work has to be calibrated to 1.8 to give me the same tonal distribution. I use a special Lab file to evaluate all my profiles, and this gives me the consistency I need for my personal and professional work. White luminance is another important setting. A pure white image in Photoshop should have about the same apparent brightness as a sheet of white paper when viewed under a D50 viewing light. If they are very different, it will be difficult or impossible to get a good monitor to print match. The brightness of the viewing light will affect apparent contrast, shadow detail, saturation, etc. I choose to set both my LCDs and CRTs to between 90 and 100 cd/m2 for consistency. This means I also need to have the same approximate ambient brightness in my room and with my viewing lights, both at home and at work. So, while some people are happy with 6500K, I'm not. The closer I can get to 5000K, given the limitations of the monitor, the better. Try them both and decide what works for you. If you are happy with your match at 6500K, stick with it. If not, try some other settings. Lou --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "marcsienicki" <marcsienicki@y...> wrote: > > Hi all. This is a follow-up question to my earlier posting on luminance level calibration. > With regards to white point, I've always left it at 6500 but wonder if I should change it to a > 5000K since I view my test prints under a D50 light source while working on them. > Thanks for helping me climb the learning curve, Marc. >
2005-12-17 by John Moody
Try both as well as native white point and use the one that seems best. Depending on your software, you may also choose one that is closest to your native white point, which would introduce less correction to the white point, which in theory should give less banding. For example, my LCD native white point is 5600, and it looks a little yellow-green. I dont have a choice for 5600, but I can pick 6000K. It corrects it to a more pleasing white, and has less banding than picking D65. Best regards, John Moody
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of marcsienicki Sent: Saturday, December 17, 2005 9:00 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] LCD calibration; which white point setting? Hi all. This is a follow-up question to my earlier posting on luminance level calibration. With regards to white point, I've always left it at 6500 but wonder if I should change it to a 5000K since I view my test prints under a D50 light source while working on them. Thanks for helping me climb the learning curve, Marc. [Non-text portions of this message have been removed]
2005-12-17 by Paul D. DeRocco
> From: marcsienicki > > Hi all. This is a follow-up question to my earlier posting on > luminance level calibration. > With regards to white point, I've always left it at 6500 but > wonder if I should change it to a > 5000K since I view my test prints under a D50 light source while > working on them. I think you should, although you lose absolute brightness when you deviate from the monitor's natural white point. Your eyes and brain largely adapt to whatever the environmental white point is, so you should only do it if your monitor's environment is your 5000K viewing area. If it's separate, then I wouldn't bother. I run my monitor at 5000K, because I'm sitting under 5000K lights, and it looks great. -- Ciao, Paul D. DeRocco Paul mailto:pderocco@...
2005-12-18 by Sam McCandless
At 4:21 PM +0000 12/17/05, Steve Kale wrote: >Marc > >You may find Bruce Fraser's book "Real World Color Management" useful. > >Steve And I don't disagree. But the first edition was published in 2003, so the second, 2004 edition seems a little long in the tooth, and I'm wondering when the third, 2006 (I assume) edition will become available. I just checked Amazon without seeing any signs of it, but I wouldn't expect to until the last minute. -- Sam
2005-12-18 by marcsienicki
Lou, Thank you for your thoughtful and helpful reply. I have also found the 6500K-calibrated monitor to have an excessively bluish hue. Following your suggestion I've tried recalibrating at 5500K but that was too yellow, but 6000K (on my monitor) seems about right. Thanks Steve for suggesting the book. Like other books in the 'Real World...' series by Fraser I would expect that much of it is aimed at commercial printers, but you are right, the parts that are relevant are among most authoritative and accurate on the subject. Marc DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina" <lbdina@c...> wrote:
> > Hi Marc. > > For over a year, I really tried to get 6500K to work for me. I > wanted, if possible, to calibrate my monitors to the Windows and WWW > standard, since that would make life easier all around. Some people > seem happy with 6500K for their personal work, but it never gave me > what I would call an acceptable monitor to print match with good custom > profiles. At 6500K, the monitor is a bluish white, so I was always > adding more yellow to compensate. My prints always looked much > yellower than my monitor (using D50 viewing lights and the same > brightness as my monitor). I knew my profiles were good. I know the > eye adapts, but mine never could make that big a leap. > > So, I spent months experimentation with color temp, gamma, luminance, > etc. I have found that when set to 6500K, neutrals on screen are very > blueish, both to the eye and measured with a spectrophotometer. 5000K > is spectrally neutral, and also happens to be about the color temp of > most printing papers. One of the whitest papers I ever use is Epson > Premium Glossy, which measures about 5200K. The rest are warmer, in > the 4800 to 5000K range. > > To complicate matters, monitors vary in quality and range. Most have a > definite "sweet spot" where they perform the best. So for me, ideally > 5000K is the best point. But lower temperatures, especially on lesser > quality monitors, can reduce gamut, smoothness, etc. If you stay > within the sweet spot of your monitor, the loss is minimal, and in my > opinion well worth a good monitor to print match. Once you step out of > the sweet spot, you begin to lose too much. For this reason, I > calibrate my monitors to somewhere between 5000K and 5500K, depending > on the actual monitor. Once I did this, my monitor to print match > became nearly perfect. The same file will now appear less blue (more > yellow) on screen and the prints match nicely. > > Contrast level also varies quite a bit from one monitor to the next. > My LCD gives me the correct distribution of tones when set to 2.2, but > my CRT at work has to be calibrated to 1.8 to give me the same tonal > distribution. I use a special Lab file to evaluate all my profiles, > and this gives me the consistency I need for my personal and > professional work. > > White luminance is another important setting. A pure white image in > Photoshop should have about the same apparent brightness as a sheet of > white paper when viewed under a D50 viewing light. If they are very > different, it will be difficult or impossible to get a good monitor to > print match. The brightness of the viewing light will affect apparent > contrast, shadow detail, saturation, etc. I choose to set both my LCDs > and CRTs to between 90 and 100 cd/m2 for consistency. This means I > also need to have the same approximate ambient brightness in my room > and with my viewing lights, both at home and at work. > > So, while some people are happy with 6500K, I'm not. The closer I can > get to 5000K, given the limitations of the monitor, the better. Try > them both and decide what works for you. If you are happy with your > match at 6500K, stick with it. If not, try some other settings. > > Lou > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "marcsienicki" > <marcsienicki@y...> wrote: > > > > Hi all. This is a follow-up question to my earlier posting on > luminance level calibration. > > With regards to white point, I've always left it at 6500 but wonder > if I should change it to a > > 5000K since I view my test prints under a D50 light source while > working on them. > > Thanks for helping me climb the learning curve, Marc. > > >
2005-12-18 by Steve Kale
You will be surprised how quickly you get used to D50 on screen. Only looks odd for a very short while. Like Lou, I also find D50 "appropriate".
> From: marcsienicki <marcsienicki@...> > > Lou, > Thank you for your thoughtful and helpful reply. I have also found the > 6500K-calibrated > monitor to have an excessively bluish hue. Following your suggestion I've > tried > recalibrating at 5500K but that was too yellow, but 6000K (on my monitor) > seems about > right. > Thanks Steve for suggesting the book. Like other books in the 'Real World...' > series by > Fraser I would expect that much of it is aimed at commercial printers, but you > are right, > the parts that are relevant are among most authoritative and accurate on the > subject. > Marc > >
