Epson Advanced B&W workflow with non Epson papers
2005-12-18 by garethjolly
I'm trying to establish a workflow using Epson advanced B&W and
Hahnmuele photo rag and am having the age old problem of matching
screen to print output.  (my screen is calibrated, incidentally)
At this stage, I don't want to use an RIP or another Epson printing
mode.  (maybe later on, but I tend to think that if I have the
Advanced B&W mode, which seems to be capable of pretty good results, I
may as well use it...)
There seem to be a few options - including
(a) the fine tradition of trial and error - tweaking the imaging using
the Advanced B&W controls & other controls (such as the paper type,
tone (normal, dark, darker etc)  (any thoughts on settings, BTW?  What
paper type should I use, for example?)
(b) printing with the 'canned' Hahnmuele photo rag ICC profile
(through Print Preview, Let Photoshop determine the colours etc, then
using Advanced B&W)
(c) creating a custom ICC by printing out a 21 step wedge then
matching it by eye to the monitor (as per Paul Roark's guide at
http://home1.gte.net/res09aij/Monitor-Profiling.htm )then using (b).
(But I can't seem to get the curve to preview properly despite
checking the preview button... using Cs2 for windows)
(d) as a final desperate possibility, create a custom curve and simply
loading it prior to printing...
Incidentally, can you proof on the lower GSM Hahnmuele photo rag, with
a view to printing the finals on the 308gsm paper?
Thanks in advance
Gareth
Re: [Digital BW] Epson Advanced B&W workflow with non Epson papers
2005-12-18 by Steve Kale
(e) create a QTR ICC profile for the Adv B&W settings you use.  If you do
not have a spectrophotometer or densitometer perhaps you could send a
printed target to someone that can read it for you.
> From: garethjolly <garethjolly@...>
> Date: Sun, 18 Dec 2005 00:21:08 -0000
> Subject: [Digital BW] Epson Advanced B&W workflow with non Epson papers
> using Advanced B&W)
> Thanks in advance
> Gareth
Thanks.  And I then use it with print it through Print Preview, Let
Photoshop determine the colours etc, then use Advanced B&W?
And a variant on that theme.  If I had a (colour) ICC created for me
by a commercial provider, could I simply use that in the same way?
The fact that it was colour presumably wouldn't matter if I was using
Advanced B&W?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
you do
> > From: garethjolly <garethjolly@b...>
papers
> > using Advanced B&W)
> > Thanks in advance
> > Gareth
2005-12-18 by wwodets
Gareth-
A color profile cannot be used to print through the ABW driver.
I have a profile for the H. Photo Rag printed through the ABW with
all settings neutral except "light" instead of "darker."  You can
also use the profile to soft proof in PS, so if your monitor profile
is accurate (and in the proper folder so that PS uses it), the screen
match is excellent.  And yes, you can proof on the lighter paper and
do a final print on the 308.  If you end up using the profile, please
send Roy Harrington 50 bucks--you'll save that much in paper and ink
costs in a week or two.  Incidentally, I've found that the 2400's are
consistent enough (sample to sample) that a "canned" profile is
probably just fine.  E-mail me if you want to try this.
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "garethjolly"
using
> Advanced B&W?
> you do
send a
> papers
matching
printing
results, I
imaging using
type,
BTW?  What
etc, then
> > > using Advanced B&W)
(b).
simply
rag, with
> > > Thanks in advance
> > > Gareth
2005-12-18 by Greg
You could use the less expensive Hahnemuhle Artproof if you can find
it. Very similar printing characteristics to most of the of their
other papers.
As far as the profiles go, I don't think the ABW mode uses a profile
at all, the profile would only be for softproofing from what I
understand. But others have more experience and will hopefully be
able to help you out.
Yes that's correct.  You plug the "missing gap" in Epson's Adv B&W workflow.
> Advanced B&W?
No.  Think of Adv B&W as an entirely different driver - it just happens to
be in the same shell as the colour driver.  The response behaviour of the
printer when controlled with Adv B&W is completely different from when it is
controlled by the colour driver.  As a result the stimulus-response
behaviour measured and used to generate the colour profile has zero
relevance to the Adv B&W driver.
Hope that makes sense.
> you do
