Quick Question on BO printing on Epson 4000
2006-01-04 by sloth4189
Can I install only the MIS Eboni cart in place of the Matte Ultrachrome or do I need to replace the light black as well with the MIS K7 equivelant ? I guess what I am saying is, in Black only print mode on matte paper using the Epson stock driver (Win XP), is the printer using ONLY the matte black cart or both the matte black AND the light black ? Thanks
2006-01-04 by Steven Karafyllakis
Hi; It uses only the matte black, that's normal for all the Epsons that will allow BO. You can get 2K printing out of it with QTR, and the difference in smoothnes is substantial, though of course more of a learning curve. Steve Karafyllakis --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sloth4189" <flamingo@t...> wrote: > > Can I install only the MIS Eboni cart in place of the Matte > Ultrachrome or do I need to replace the light black as well with the > MIS K7 equivelant ? > > I guess what I am saying is, in Black only print mode on matte paper > using the Epson stock driver (Win XP), is the printer using ONLY the
> matte black cart or both the matte black AND the light black ? > > Thanks >
2006-01-04 by Michael Vendrell
Only the Black not the light black. See clayto Jones FAQ. Michael Vendrell --- sloth4189 <flamingo@...> wrote: > Can I install only the MIS Eboni cart in place of > the Matte > Ultrachrome or do I need to replace the light black > as well with the > MIS K7 equivelant ? > > I guess what I am saying is, in Black only print > mode on matte paper > using the Epson stock driver (Win XP), is the > printer using ONLY the > matte black cart or both the matte black AND the > light black ? > > Thanks > > > > __________________________________________ Yahoo! DSL \ufffd Something to write home about. Just $16.99/mo. or less. dsl.yahoo.com
Steve (and Michael): Thanks for that info. On the other side of the coin, when printing color on the 4000 using the stock Epson (WinXP) driver, are only the color inks used or are the black inks used as well, and if so, how does the MIS Eboni ink mix with the standard Epson UltraChromes ? Thanks again. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis" <steve@s...> wrote: > > Hi; > > It uses only the matte black, that's normal for all the Epsons that
> will allow BO. You can get 2K printing out of it with QTR, and the > difference in smoothnes is substantial, though of course more of a > learning curve. > > Steve Karafyllakis > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sloth4189" > <flamingo@t...> wrote: > > > > Can I install only the MIS Eboni cart in place of the Matte > > Ultrachrome or do I need to replace the light black as well with > the > > MIS K7 equivelant ? > > > > I guess what I am saying is, in Black only print mode on matte > paper > > using the Epson stock driver (Win XP), is the printer using ONLY > the > > matte black cart or both the matte black AND the light black ? > > > > Thanks > > >
I went through a similar transition with my 7600 and the standard UC inks; I don't remember there being any major problem, but perhaps someone else has more recent experience to relate? I'm now using the MIS Pro inks which are much better than the old UC inks: better color gamut, and almost non-existent bronzing on RC papers-not to mention a great deal cheaper. Highly recommended! Steve --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sloth4189" <flamingo@t...> wrote: > > Steve (and Michael): > > Thanks for that info. > On the other side of the coin, when printing color on the 4000 using > the stock Epson (WinXP) driver, are only the color inks used or are > the black inks used as well, and if so, how does the MIS Eboni ink > mix with the standard Epson UltraChromes ? > > Thanks again. > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven > Karafyllakis" <steve@s...> wrote: > > > > Hi; > > > > It uses only the matte black, that's normal for all the Epsons > that > > will allow BO. You can get 2K printing out of it with QTR, and the > > difference in smoothnes is substantial, though of course more of a > > learning curve. > > > > Steve Karafyllakis > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sloth4189" > > <flamingo@t...> wrote: > > > > > > Can I install only the MIS Eboni cart in place of the Matte > > > Ultrachrome or do I need to replace the light black as well with > > the > > > MIS K7 equivelant ? > > > > > > I guess what I am saying is, in Black only print mode on matte > > paper > > > using the Epson stock driver (Win XP), is the printer using ONLY
> > the > > > matte black cart or both the matte black AND the light black ? > > > > > > Thanks > > > > > >
2006-01-04 by Chris Hargens
Are you using custom profiles for your color printing with the MIS Pro inks? I've thought about giving them a go with my 2200, but I hesitate because I'm not sure that I'd have to get a whole new set of profiles. Chris Hargens --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven Karafyllakis" <steve@s...> wrote:
> I'm now using the > MIS Pro inks which are much better than the old UC inks: better > color gamut, and almost non-existent bronzing on RC papers-not to > mention a great deal cheaper. Highly recommended! > > Steve
2006-01-12 by steveabrink
I talked to MIS the other day about this and they said you can use Epson profiles but be warned they will probably not be accurate. I would need 12 color and 4-5 QTR profiles, so its out of the question for me... Supposedly they will make profiles in the fuure but he said it was at least a year away... Too bad. SteveB -- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Chris Hargens" <chargens@s...> wrote:
> > Are you using custom profiles for your color printing with the MIS Pro > inks? I've thought about giving them a go with my 2200, but I hesitate > because I'm not sure that I'd have to get a whole new set of profiles. > > Chris Hargens > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven > Karafyllakis" <steve@s...> wrote: > > I'm now using the > > MIS Pro inks which are much better than the old UC inks: better > > color gamut, and almost non-existent bronzing on RC papers-not to > > mention a great deal cheaper. Highly recommended! > > > > Steve >
2006-01-12 by Steven Karafyllakis
There's at least one app that I'm aware of that allows you to edit standard icc profiles. I've never tried it, but last time I checked they had a demo version: http://www.antelligent.com/pages/ps_plugins.html It costs $75.00, quite reasonable if it works well Steve Karafyllakis --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "steveabrink" <steveabrink@y...> wrote: > > I talked to MIS the other day about this and they said you can use > Epson profiles but be warned they will probably not be accurate. > I would need 12 color and 4-5 QTR profiles, so its out of the question > for me... Supposedly they will make profiles in the fuure but he said > it was at least a year away... Too bad. > SteveB > > > -- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Chris Hargens" > <chargens@s...> wrote: > > > > Are you using custom profiles for your color printing with the MIS Pro > > inks? I've thought about giving them a go with my 2200, but I hesitate > > because I'm not sure that I'd have to get a whole new set of profiles. > > > > Chris Hargens > > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven > > Karafyllakis" <steve@s...> wrote: > > > I'm now using the > > > MIS Pro inks which are much better than the old UC inks: better > > > color gamut, and almost non-existent bronzing on RC papers-not to
> > > mention a great deal cheaper. Highly recommended! > > > > > > Steve > > >
2006-01-12 by Ernst Dinkla
> Steve Karafyllakis
At least an interesting price.
Does Doctor Pro edit standard ICC profiles or only the
Colorvision profiles?
Kodak Custom Color Tools edits standard profiles, input,
output, monitor, abstract, and in both directions: to device
and to PCS. It is expensive. Very good program though.
Ernst
Ernst Dinkla
www.pigment-print.com
( unvollendet )2006-01-12 by colingruk
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "steveabrink" <steveabrink@y...> wrote: > > I talked to MIS the other day about this and they said you can use > Epson profiles but be warned they will probably not be accurate. > I would need 12 color and 4-5 QTR profiles, so its out of the question > for me... Supposedly they will make profiles in the fuure but he said > it was at least a year away... Too bad. > SteveB I found that I needed profiles for more accurate rendition of sandstones. The profile I ordered from a profiler in the UK is in my Inbox and I hope to try it at the weekend. Colin
