PrintFix spectro
2006-01-12 by wgh2005
The PrintFixPRO package uses a colorimeter called (somewhat inaccurately) the "Spectro 1005". It is not a spectrophotometer. The difference between the PLUS and the PRO versions, once they're released, is not that there are two different colorimeters. The PLUS version, if I understand correctly, will be only the software in the release version. The PRO version will have both the software and the colorimeter. It will not be quite as accurate as a $2000 to $4000 Gretag Macbeth system, but it's a couple of thousand dollars cheaper - and with an adjustment or two, the profiles can be as good as those from the more expensive packageAt least that's been my early experience and the experience of several others who have beta-tested the program. As I mentioned in an early post, the two profiles I've made using this package produced profiles which required only a single minor adjustment in each of them, to make the print match the monitor perfectly. I should use quotes around that word "perfectly" because of course a print will never look **exactly** like the monitor, for several different reasons (different gamut, reflected versus emitted light, etc etc). What I mean is that color balance, brightness, contrast, and saturation were all spot on after that single adjustment. Each profile took about 20 minutes (or less? I didn't keep exact track) to make, including the time it took to print out the reference image, print out three of my own reference images, and make the adjustments. I'll work with my sample of the commercially released PrintFixPRO package for a while and then get back to the group with a progress report. Early experience is far far better than I'd thought it would be. Bill Hansen
