Another Silver Rag Review-cross posted
2006-02-08 by john dean
I have done the beta tests of Silver Rag along with many other people around here and here is a synopsis of what I found out. I agree with the previous posters on this toppic Keith Johnson and Ellie Kennard (you can search these archives as well as the digital large format list for their comments), that it is a very interesing and innovative paper. I actually liked it even better than I had thought I would and, my clients are already wanting me to do work for them on it. For me it is a huge step beyond rc. Like Keith, it is the kind of thing that makes me want to reprint past work with it. It is strikingly close to the old Agfacolor fiber based type c media that was abandoned after everything went rc. And, I always loved that surface and opulance. 1. In tests on the Epson 2400 K3 machine, the black and white work was perfect using the ABM mode, very neutral, intense blacks, and no gloss differential or bronzing at all, none. The color gamut for a color tests was excellent. This inkset and this media is a perfect combination. This would be my first choice, definitely. Its a breeze. 2. Much to my surprise the color tests with Ultrachrome K2 and the 9600 using PK and the Crane supplied SR profile was also really nice. By really nice I mean more of a brilliant expanded gamut than the same file printed on Hahnemuhle Photo Rag with a custom profile and much blacker blacks. I am not doing scientific measurements or dmax density plots but direct visual expriments. Of course the rc gloss papers with PK also give you a better gamut and dmax than matte rag media so this is no surprise. As to gloss differential with the color 9600 prints it is almost invisible, it has the very very slight relief effect of a dye transfer print, you really have to look for it under strong light at a specific angle. I did a 16x20 without spraying it and it is gorgeous the way it is. With Premium Luster Epson I ALWAYS have to either spray or laminate the work because of the gloss and bronzing problems. 3.What surprised me also was that I was able to do some nice black and white prints using QTR and the 9600 PK on the Silver Rag. But, only after spraying with Premier Art spray. When I first printed the print I was able to achieve a nice neutral print easily, with fantastic tonal range and dmax but the gloss differential and shadow bronzing was pretty major (like all the gloss papers printed this way). I tried spraying the monochrome prints with K2 with the Lascaux spray and it didn't change anything for me. But when I tried some using Premier Art the bronzing went away totally and the gloss differential fell in line with the color work, which is to say you have to look very very hard to see the relief image at all (like dye transfer prints). The print color with QTR is controlable enought to produce neutral, warm, and probably sepia work on it. 4. Finally, I tested SR with the Piezo Tone K6 neutral inkset on my 7000. The image did stick with no rub off, the tonal range was outstanding even without any kind of curve made for this media, the color warm neutral, almost exactly like Portriga Rapid. However, the gloss differential and the bronzing in the maximum back areas was totally horrible. No spray helped. To be fair though this is a matte black in that inkset with heavy carbon content, and this paper was definitely designed for PK. Also with a rip and channel partitioning to control the amount of ink being laid down in the deepest blacks, it might be possible to use this inkset for it, but you would have to substitue somekind of photo black in there and who knows what that would do to the carefully worked out consistency of the neutral color. I'll leave that test to others. But if I were Inkjet Mall I would certainly be seriously considering this possibility because the combination would be awesome if possible. Apparently the Cone Quads don't stick at all and are not workable. Now the texture. I like it fine. It is to me somewhere between an Epson Semi Gloss RC surface and the dye transfer color fiber paper mentioned before. Once flattened the prints lie flat for me, and curl on a roll the same way a gelatin silver paper would. Of course the rc glossy papers curl a lot too. With the prints that I sprayed with Premier Art spray this very slight texture is amost totally smoothed out, and then you really have a darkroom gelatin silver look, if that is important to you. This texture being a very slight luster, is not the kind of mechanical texture you get with Premium Luster or Type C luster which is run through a texture machine. It looks more natural to me. We will have to work a few months with this media to explore it fully but so far I'm impressed and wish I had it 7 years ago. The only thing we don't know about this coating is its potential longevity. In order for me to start really cranking out tons of work with it I want to learn someting substantial in this regard. Lets hope Crane is working on that now. John
