I need help with carbon settings
2006-02-24 by lovelipp
I use UT7 inks,a 7600 printer and HPR. New problem: When I load the
Roark/Schwab curves for carbon, the print is very washed out, which
didn't used to happen. I uninstalled and re-installed the curves with
no luck. With no slider settings at all, I get a very cool almost
greenish print. The order of my carts, l.to r: Eboni, Lt Bl, Cyan, Mag,
Lt Cyan, Lt Mag, Yellow.They've always been in this order, and I was
always able to get the range from to cool thru sepia loading the
Roark/Scwab curves.
Now I'm using sliders instead. Has anyone worked out slider settings
that replicate the carbon tone, the medium warm and sepia?
Again, many thanks to you all,
Arlene
