R800 Banding
R800 Banding
2006-02-27 by Gib Robinson
The last two weeks I've seen banding on prints (both color & B&W) made on my
R800. I have no idea why or whether there is a solution to it. I've had the
printer for about two years and used it extensively so I suppose it could
just be wear. If there is a fix I'd love to hear about it. Would QTR be
likely to help?
In the long run (next few months) I hope to buy a K3 ink printer, but I'd
love to keep this one for glossy printing.
--Gib
Re: R800 Banding
2006-02-27 by Stephen Kobrin
Gib,
I am sure you have thought of this, but just in case have you run a
nozzle check?  I have an 800 and had a clog in one cart that resulted
in banding and other assorted problems.  As I recall, there is a
smart clean cycle that deals only with the effected cart on the 800.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gib Robinson"
made on my
had the
could
QTR be
> likely to help?
but I'd
> Thanks,
> --Gib
Re: R800 Banding
2006-02-27 by Gilbert Robinson
Thank you, Steve.
I did run a nozzle check and realigned the heads. That helped with the
most egregious banding, but I still get some banding at the end (last
1/2 inch or so) of several images.
--Gib
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Kobrin"
<kobrins@...> wrote:
> Gib,
> Steve
> made on my
> had the
> could
> QTR be
> > likely to help?
> but I'd
> > Thanks,
> > --Gib
Re: R800 Banding
2006-02-27 by bwinkjet
Hi Gilbert,
With banding the last 1/2 inch or so, it is possible the feed rollers
are dirty.  Try cleaning these by running a sheet of matt paper
sprayed with Windex on both sides through repeatedly and see if that
helps.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gilbert
Robinson" <robinson@...> wrote:
> Thank you, Steve.
(last
> --Gib
Kobrin"
> <kobrins@> wrote:
> > Gib,
a
resulted
800.
> > Steve
Robinson"
B&W)
> > made on my
I've
> > had the
suppose it
> > could
Would
> > QTR be
> > > likely to help?
printer,
> > but I'd
> > > Thanks,
> > > --Gib
