Black Only printing with R2400
2006-03-17 by dgattarino
Hi to all,
I had been reading recently some Clayton Johnes paper and got
interested in BO printing. However, I own a R2400 printer which daesnt
supporte it natively. How do I print BO in that case? Would QTR with a
profile where
only the Black ink is switched on solve the problem?
Thanks for your comments.
     Daniela
Re: Black Only printing with R2400
2006-03-17 by alanrew42
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dgattarino"
<dgattarino@...> wrote:
> Hi to all,
> profile where
>      Daniela
What do you mean by "doesn't support it natively"?
Does this mean you've tried his advice on
http://www.cjcom.net/articles/digiprn9.htm
and it doesn't work?
Unfortunately, that's not BO printing. Read, infact, the last section
of the papr you mentioned
Cheers
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "alanrew42"
> <dgattarino@> wrote:
> > Hi to all,
> > profile where
> >      Daniela
2006-03-17 by Tim Atherton
It means the 2400 doesn't have a setting for BO printing
Presumably because it's not BO Printing?
That's for printing using the Epson ABW software.
I presume someone wants to use BO pritnign to get the punchy/slightly
grainy "Tri-X" look it gives. Not one that I personally like, but it
appeals to some
(BTW there are a couple of 2400 profiles in QTR which work pretty well
and give a slightly different look than the ABW)
tim a
2006-03-18 by jlk4410
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dgattarino" <dgattarino@...> wrote:
> Hi to all,
> profile where
>      Daniela
My R2400 Epson software has a setting for BLACK, under"print settings">"color" . Clayton has
been a great source for me perhaps his instructions could help?
Julian Kaiser
2006-03-18 by Clayton Jones
Hello Julian,
>My R2400 Epson software has a setting for BLACK, under "print
>settings">"color" .
Now you have my curiosity up, but I can't find this.  Can you describe
in more detail where you see it?  Many thanks.
Clayton
2006-03-18 by dgattarino
Hi Julian,
my Epson software daesnt have that setting you are mentioning.
Daniela
<cj@...> wrote:
> Hello Julian,
> >settings">"color" .
> Regards,
> Clayton
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote:
> Hello Julian,
> >settings">"color" .
> Regards,
> Clayton
Yo Clayton!{and everyone else out there}
Remembering I'm on a Mac, OS10.4.5, with the latest driver from the Epson site.
 When I print,{command P} the first window has a pull down menu-default says"copies and
pages". Pull down to "printer settings" The next window, go to COLOR:choices are:Color/
Advanced B&W/ BLACK. I have the Image profile set for 20% dot gain, PS2 is managing
color, printer profile is 20% dot gain.
I've been working in ABW 'mode' and falling in love with Kayenta! Haven't
explored all the settings in the Epson driver,{been using a workflow from that guy Clayton}
Do you know where I can find a good set of instructions for the R2400? Not happy with the
one that came in the box. My issues are dumb things like paper not catching-not
feeding;controlling roll paper feed. Maybe I just need more time on the machine?
Thank You Clayton! You Rule!
Julian Kaiser
Hello Julian,
>Epson site.
Ok, understood.  My PC version is nothing like this.
>COLOR:choices are:Color/Advanced B&W/ BLACK.
What happens when you choose BLACK?
Yes, Kayenta is really nice paper, one of my favorites.
Who?  Never heard of him.
>R2400? Not happy with the one that came in the box.
No, sorry.
>My issues are dumb things like paper not catching-not feeding
I found that putting a slight bend in the stiff/thick papers helps it
feed into the jaws of the grabber easier.  It also helps to give it a
firm but brief nudge to move it forward into the grabber - just a tiny
bit.  Too much and it will be rejected and passed through.
Clayton
2006-03-18 by how786
Julian,
 Guess what? I had the very same issue with paper not catching on my
2400. It drove me crazy. I called Epson tech support several times and
tried their suggestions. Only lightweight papers went thru the printer
easily.
 Finally, they sent me a new printer and the issues disappered! Even
heavier weight papers fly thru just fine.
 I suggest that you do the same. They are well aware that there are
issues with paper feeding and the 2400.
 Good luck!
 Howard
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jlk4410"
<cj@> wrote:
> > Hello Julian,
> > >settings">"color" .
> > Regards,
> > Clayton
Epson site.
PS2 is managing
Haven't
catching-not
the machine?
> Julian Kaiser
2006-03-18 by Stephen Kobrin
While they are very different printers, this sounds a lot like the
issues that some of us had with the R800.  I had to send the first
one back as its paper feed drove me nuts.  Epson sent me a new one
which works well, but for the occasional time the gremlins decide to
feed a sheet straight through without stopping for ink.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "how786"
<how786@...> wrote:
> Julian,
and
printer
> easily.
>  Good luck!
>  Howard
> Hello Julian,
I get a print with a more "choked" greyscale. Not bad,shadows blocked up, more contrasty,
and it looks like it would be worth exploring.
Thanks, tried a bend, tried multiple sheets& prayer! Experienced what you describe with
the "nudge".
Howard suggested he had the same issues and that Epson sent him a new machine as they
were aware of problems.
 julian kaiser
2006-03-19 by joemulligan_68
I hope to chime in.  I purchased a 7800 two weeks ago which has the
latest 2.7 driver being run on Mac OSX 10.3.  From reading on this
forum, I was under the impression that there is no Black mode for
the K3 printers.  Well, there is a setting.  I have the option of
choosing Color, Advanced B&W, or Black.  Out of curiosity, I printed
one image under Black mode on Ilford Smooth Pearl paper.  The result
was a very warm print with good detail.  Looks similar to the prints
I would get when printing BO with my 4000.  The image bronzes while
the same print on Advanced B&W does not.  Now I wonder whether the
PK on the K3 inkset is actually the same as the old Ultrachromes.
Maybe someone with more experience with the x800 printers can
comment.
JM
> Hi Julian,
> Regards,
> Daniela
Jones"
> <cj@> wrote:
> > Hello Julian,
> > >settings">"color" .
describe
> > Regards,
> > Clayton
2006-03-19 by bwbonkers
Are you MAC or PC. I'm on a MAC and my driver has the Black setting. The question is what
does it do. Anyone.
Peter.
Re: [Digital BW] Re: Black Only printing with R2400
2006-03-19 by Carl Schofield
It says black but really still prints using all colors.
> does it do. Anyone.
> Peter.
2006-03-19 by Steve Kale
This has been discussed before.  According to Epson it depends on the paper.
On any decent photographic paper it uses all the grey/black inks.
> From: bwbonkers <PeterDLevis@...>
> Date: Sun, 19 Mar 2006 19:34:51 -0000
> Subject: [Digital BW] Re: Black Only printing with R2400
> question is what
> does it do. Anyone.
> Peter.
2006-03-20 by Carl Schofield
Interesting that the 7800 "Black" driver option behaves differently
compared to the same option in the 2400 driver.  The latter produces
a greenish black print and under magnification you can see CMY dots.
Sounds like the 7800 is doing true BO.
> comment.
> JM
>> Hi Julian,
>> Regards,
>> Daniela
> Jones"
>> <cj@> wrote:
>>> Hello Julian,
>>>> settings">"color" .
> describe
>>> Regards,
>>> Clayton
> If you wish to receive no emails or just a daily digest, or you
> wish to unsubscribe, please edit your Membership preferences by
> visiting this same page.
> - As threads develop, trim off excess portions of earlier messages
> to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> - By posting on this forum you agree to abide by the group rules
> and guidelines, and to abide by the actions and decisions of the
> group Owner and Moderators. See “Group Topic, Rules and Guidelines”
> in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER
> INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL
> BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF
> SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
> THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO
> OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO
> GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
