Is anyone using MIS K4 inks for the R2400?
2006-03-19 by gguhangunaratnam
Hello, Is anyone using the MIS K4 inks for the R2400? How do you like them? How do you feel they compare to the K3 inks? Do you use the CFS or carts? Thanks
2006-03-19 by bwbonkers
Hi Yep. I'm using MIS K4 inks in my 2400. I use the easyfill carts. Problems so far are nil. The inks are very good. I only use photo black and mainly print on satin papers such as Ilford Smooth pearl for B&W and Olmec Satin for colour. On satin/pearl papers I cannot really tell the difference between OEM inks and MIS. On glossy media the OEM inks are slightly better because they show no signs of bronzing whereas the MIS inks show just a little. When you compare the cost the MIS inks win and I am delighted with the results. I have not tried them on art papers using mK black so cannot comment. Hope this helps. Regards Peter.
2006-03-19 by Matt Haber
I am--I am using the carts (I got a prefilled set, and i have the 4 oz replacements--really easy to refill, though the plug is curiously surrounded by a lip, making it harder to remove than the 1280 spongeless carts) I have only had them a couple of weeks, just long enough to make a color profile for PGPP and do some client work. Color (with the profile) is as good as K3, though there is a bit more gloss differential then with the K3 on glossy. I suspect that the profiles posted are not usable on the the 2400. I have not had time to check the usability of the ABW settings, or see if QTR will be necessary. Let me know (on or off list) if you have further questions. -matt > Hello, > > Is anyone using the MIS K4 inks for the R2400? How do you like them? > How do you feel they compare to the K3 inks? Do you use the CFS or > carts? -- Matt Haber dance, portrait and fashion photography http://www.matthaber.com
Yay, someone is using it. Thanks for replying Matt. That's too bad to hear there is more bronzing with the K4 inks in color. Do you think you just need to fine tune your profile/printing workflow? I'll be very interested to know what you think after trying out some B&W with the ABW settings. I won't be able to afford to make my own profiles at the moment, so if I start to use the K4 inks I need to find profiles online. I'm leaning towards the CFS right now. I've never owned/used one, but it seems a little easier now than those I saw in the past. I wonder if spongeless carts will be easier though. Did you consider the CFS? Why aren't more using this inkset? The R2400 has been a good seller, and Eboni is also popular...is this inkset very very new? Thanks again for the info Matt, as you continue to use the K4 inks I'd like to hear your ongoing experiences. Guhan --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Matt Haber" <matt@...> wrote: > > I am--I am using the carts (I got a prefilled set, and i have the 4 oz > replacements--really easy to refill, though the plug is curiously > surrounded by a lip, making it harder to remove than the 1280 > spongeless carts) > > I have only had them a couple of weeks, just long enough to make a > color profile for PGPP and do some client work. Color (with the > profile) is as good as K3, though there is a bit more gloss differential
> then with the K3 on glossy. I suspect that the profiles posted are not > usable on the the 2400. I have not had time to check the usability of > the ABW settings, or see if QTR will be necessary. > > Let me know (on or off list) if you have further questions. > > -matt > > Hello, > > > > Is anyone using the MIS K4 inks for the R2400? How do you like them? > > How do you feel they compare to the K3 inks? Do you use the CFS or > > carts? > > -- > Matt Haber > dance, portrait and fashion photography > http://www.matthaber.com >
2006-03-20 by Carl Schofield
I'm using MIS K4 in my 2400 and have icc profiles for use with ABW mode. Prints are excellent with no bronzing or gloss diff. Profiles are available here: http://homepage.mac.com/scho/FileSharing3.html
On Mar 19, 2006, at 6:23 PM, gguhangunaratnam wrote: > Yay, someone is using it. Thanks for replying Matt. That's too bad > to hear there is more bronzing with the K4 inks in color. Do you > think you just need to fine tune your profile/printing workflow? > > I'll be very interested to know what you think after trying out some > B&W with the ABW settings. I won't be able to afford to make my own > profiles at the moment, so if I start to use the K4 inks I need to > find profiles online. > > I'm leaning towards the CFS right now. I've never owned/used one, but > it seems a little easier now than those I saw in the past. I wonder > if spongeless carts will be easier though. Did you consider the CFS? > > Why aren't more using this inkset? The R2400 has been a good seller, > and Eboni is also popular...is this inkset very very new? > > Thanks again for the info Matt, as you continue to use the K4 inks I'd > like to hear your ongoing experiences. > > Guhan > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Matt Haber" > <matt@...> wrote: >> >> I am--I am using the carts (I got a prefilled set, and i have the >> 4 oz >> replacements--really easy to refill, though the plug is curiously >> surrounded by a lip, making it harder to remove than the 1280 >> spongeless carts) >> >> I have only had them a couple of weeks, just long enough to make a >> color profile for PGPP and do some client work. Color (with the >> profile) is as good as K3, though there is a bit more gloss > differential >> then with the K3 on glossy. I suspect that the profiles posted are >> not >> usable on the the 2400. I have not had time to check the usability of >> the ABW settings, or see if QTR will be necessary. >> >> Let me know (on or off list) if you have further questions. >> >> -matt >>> Hello, >>> >>> Is anyone using the MIS K4 inks for the R2400? How do you like >>> them? >>> How do you feel they compare to the K3 inks? Do you use the CFS or >>> carts? >> >> -- >> Matt Haber >> dance, portrait and fashion photography >> http://www.matthaber.com >> > > > > > > > > Please visit the Group Homepage to check the Files, and other > resources as they are often being updated. > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you > wish to unsubscribe, please edit your Membership preferences by > visiting this same page. > > Please follow these basic guidelines: > - As threads develop, trim off excess portions of earlier messages > to keep them short. > - Good manners are required at all time. No personal attacks or > flames. Hostile, aggressive or argumentative users may be removed > from the membership without notice. > - Keep your posts and threads related to the group topic of digital > B&W printing. Users who persistently make off-topic posts may be > removed from the membership. > - By posting on this forum you agree to abide by the group rules > and guidelines, and to abide by the actions and decisions of the > group Owner and Moderators. See “Group Topic, Rules and Guidelines” > in the Files section: > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE > “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL > NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, > CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, > DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER > INTANGIBLE LOSSES (EVEN IF THE “OWNER” AND “MODERATORS” OF DIGITAL > BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF > SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE > THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO > OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR > CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO > GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > PRINT YAHOO GROUP. > > Yahoo! Groups Links > > > > > >
2006-03-20 by sburger104@aol.com
I'm using the spongeless cartridges and the K4 inks. The big cosideration between going spongeless carts verses a CFS unit is the types of paper to be used. If you will be switching back and forth between the Photo black and Matte black inks, the spongeless carts are the way to go. If you print on matte papers only, or if you print on glossy,luster, or semi-gloss papers exclusively, CFS units are great. The spongeless cartridge system works very well. I have had no glitches. The K4 inks are exceptional. Even the Epson canned profile for Velvet Fine works well. I have made a custom profile and it is better though. The black & white prints are exceptional. The black & white prints on the 2400 are great. The print driver offers a ton of control. Steve Burger [Non-text portions of this message have been removed]
2006-03-20 by gguhangunaratnam
Thanks a lot Carl, do you know where I might be able to find profiles for EEM, VFA, Kayenta or Silver Rag? Thanks again --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield <scho@...> wrote:
> > I'm using MIS K4 in my 2400 and have icc profiles for use with ABW > mode. Prints are excellent with no bronzing or gloss diff. Profiles > are available here: > http://homepage.mac.com/scho/FileSharing3.html > > On Mar 19, 2006, at 6:23 PM, gguhangunaratnam wrote: > > > Yay, someone is using it. Thanks for replying Matt. That's too bad > > to hear there is more bronzing with the K4 inks in color. Do you > > think you just need to fine tune your profile/printing workflow? > > > > I'll be very interested to know what you think after trying out some > > B&W with the ABW settings. I won't be able to afford to make my own > > profiles at the moment, so if I start to use the K4 inks I need to > > find profiles online. > > > > I'm leaning towards the CFS right now. I've never owned/used one, but > > it seems a little easier now than those I saw in the past. I wonder > > if spongeless carts will be easier though. Did you consider the CFS? > > > > Why aren't more using this inkset? The R2400 has been a good seller, > > and Eboni is also popular...is this inkset very very new? > > > > Thanks again for the info Matt, as you continue to use the K4 inks I'd > > like to hear your ongoing experiences. > > > > Guhan > > > > > > > > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Matt Haber" > > <matt@> wrote: > >> > >> I am--I am using the carts (I got a prefilled set, and i have the > >> 4 oz > >> replacements--really easy to refill, though the plug is curiously > >> surrounded by a lip, making it harder to remove than the 1280 > >> spongeless carts) > >> > >> I have only had them a couple of weeks, just long enough to make a > >> color profile for PGPP and do some client work. Color (with the > >> profile) is as good as K3, though there is a bit more gloss > > differential > >> then with the K3 on glossy. I suspect that the profiles posted are > >> not > >> usable on the the 2400. I have not had time to check the usability of > >> the ABW settings, or see if QTR will be necessary. > >> > >> Let me know (on or off list) if you have further questions. > >> > >> -matt > >>> Hello, > >>> > >>> Is anyone using the MIS K4 inks for the R2400? How do you like > >>> them? > >>> How do you feel they compare to the K3 inks? Do you use the CFS or > >>> carts? > >> > >> -- > >> Matt Haber > >> dance, portrait and fashion photography > >> http://www.matthaber.com > >> > > > > > > > > > > > > > > > > Please visit the Group Homepage to check the Files, and other > > resources as they are often being updated. > > > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > > > If you wish to receive no emails or just a daily digest, or you > > wish to unsubscribe, please edit your Membership preferences by > > visiting this same page. > > > > Please follow these basic guidelines: > > - As threads develop, trim off excess portions of earlier messages > > to keep them short. > > - Good manners are required at all time. No personal attacks or > > flames. Hostile, aggressive or argumentative users may be removed > > from the membership without notice. > > - Keep your posts and threads related to the group topic of digital > > B&W printing. Users who persistently make off-topic posts may be > > removed from the membership. > > - By posting on this forum you agree to abide by the group rules > > and guidelines, and to abide by the actions and decisions of the > > group Owner and Moderators. See "Group Topic, Rules and Guidelines" > > in the Files section: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > > PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE > > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL > > NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, > > CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, > > DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER > > INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL > > BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF > > SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE > > THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO > > OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR > > CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO > > GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > > PRINT YAHOO GROUP. > > > > Yahoo! Groups Links > > > > > > > > > > > > >
Thanks Peter, can you tell me what profiles you are using (your own?) Your experience with bronzing is consistent with Carl on glossy papers. What about the fade resistance/archival quality compared to the K3 inks? And the price certainly is great. I just don't want to have to reprint due to fading. I'm referring to colour photos. For B&W and I assume I'd need to use a RIP to only use the Eboni in BO fashion for best archival quality. Thanks again --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bwbonkers" <PeterDLevis@...> wrote:
> > Hi > > Yep. I'm using MIS K4 inks in my 2400. I use the easyfill carts. > Problems so far are nil. The inks are very good. I only use photo black > and mainly print on satin papers such as Ilford Smooth pearl for B&W > and Olmec Satin for colour. On satin/pearl papers I cannot really tell > the difference between OEM inks and MIS. On glossy media the OEM inks > are slightly better because they show no signs of bronzing whereas the > MIS inks show just a little. When you compare the cost the MIS inks win > and I am delighted with the results. I have not tried them on art > papers using mK black so cannot comment. Hope this helps. > > Regards Peter. >
2006-03-20 by bwbonkers
I use my own custom made profiles using an EyeOne. For BW I use the ABW mode in the Epson driver. Again I profile using QTR create ICC program that's part of QTR. I nolonger use a RIP. Not sure about BO. As far as fading goes I cannot really comment as I have not done any tests. I'm sure others in the group more qualified than me could help here. If you are not sure then maybe its worth just buying a set of carts to try. The ink is compatable with Epsons so its easy to switch back if you don't like what you see. Could be wrong here but I think the prefilled MIS carts are the clear easyfill type carts so are refillable. Worth checking with MIS. Rggards Peter.
