Re: [Digital BW] Re: Epson Velvet Fine Art greyed out in Epson driver
2006-03-22 by Tina Manley
At 08:14 PM 3/21/2006, you wrote:
>Thanks Tina,
>When I choose any of the three manual feeds I can use these media types now.
>Does that mean Clayton and all others manually feed the paper (I would have
>done this for final prints since I wouldn't have paper sitting in the
>printer, but for EEM, my proof paper, I'd like to be able to have some
>sitting in the automatic feeder.  In this situation, I'm using the VFA media
>type, but actually printing on EEM (as Clayton describes is best/a good
>starting point).
Yes, with these paper choices you have to select Manual because they
are thicker papers that have to be fed and adjusted sheet by
sheet.  I don't know of any way around this.  The Ultrasmooth Fine
Art and the Velvet Fine Art are much thicker than Epson Enhanced
Matte.  If I were you, I'd choose EEM for the print proofs and then,
if you want to print on the thicker papers, choose ESFA or VFA for
the final prints.  There won't be much, if any, difference.
>I also noticed that the printable area is much smaller when feeding from the
>front (when I chose manaul front feed the image which was previously
>printable unclipped, required clipping with the feeding method).  Why is
>that?
I've noticed that, too, but usually if you ignore the warning and go
ahead and print what you know will fit, it will fit with no
problems.  Just try it and see.
Good luck!
Tina
