Coating for MIS K4 on canvas
2006-04-04 by Ernst Dinkla
Which coating on MIS K4 (Eboni included) + canvas will not
produce the yellowing we observe right now with Lascaux
Varnish Gloss and Matte ? Printed with a 9800.
The Epson K3 on the same canvas doesn't show the effect at
all. MIS 7600 with a 9600 on the same canvas showed it a bit
but acceptable.
Spraying with a solvent varnish before the Lascaux  waterbased
acrylic is applied doesn't help either, even the spray creates
the effect.
Meanwhile there are several reasons to return to Epson K3 or
MIS 7600 on the 9800. If the base of the K4 is the problem
then changing to MIS Pro will not help either as it  should
have the same base.
Ernst
           Ernst Dinkla
www.pigment-print.com
(         unvollendet         )
