Epson R2400 Printer
2006-04-19 by maddoxmb
Does anyone have their R2400 Printer set up as a shared network printer? Are you doing this on a Mac OSX computer accessing with another Mac OSX computer? I spent about 10 hours yesterday attempting to get this to work with no luck. I'm just trying to see if I am barking up the wrong tree?
2006-04-20 by Bob Marsolais
This is a bit off topic, but hopefully this will quickly solve your problem. I have installed Epson C84, C86, C880, and 1280 printers as shared network printers in a Windows Environment using printer servers from 4 different manufacturers, including Epson. Print servers are necessary since these models do not have a built-in network interface. I have used both USB and parallel printer ports. They always work with one exception: you cannot read back the printer ink levels or any other printer status with the exception of a generic paper error. The reason, according to more than one printer and server manufacturer, is that there is no standard way to communicate printer status to/from the print server and the printer. This made sense when combining an Epson printer with a non-Epson server, but I had the same problem when I tried to connect my 1280 to the network using the Epson print server. My conclusion was that it is not possible to get full printer functionality over a network unless the printer has a built-in network interface. The only other option I know, in a Windows environment, is to connect the printer to a computer and then allow that computer to share the printer with other computers on the network . That works. Bob --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "maddoxmb" <maddoxmb@...> wrote: > > Does anyone have their R2400 Printer set up as a shared network printer? Are you doing this > on a Mac OSX computer accessing with another Mac OSX computer? I spent about 10 hours > yesterday attempting to get this to work with no luck. I'm just trying to see if I am barking > up the wrong tree? >
