First black and white print
2006-04-27 by chas4452
Hi all
This is my first post although I have been reading the forum for
some time. Until recently I was a diehard darkroom worker of some
twenty years and felt pretty negative towards digital. But I have
been inspired by the forum and particular thanks to Clayton and Paul
for all the info on their sites.
So I have just made my first print with an Epson R220 and MIS UTR2
inks and have a question. I decided to do a BO print and understood
from the forum that the print dialogue box should have a checkbox
for 'black only'. If it said 'grayscale'as mine did, then you had to
download the latest XP driver from the Epson website - 5.5A. This I
did more than once and it still showed 'Grayscale'. I phoned Epson
technical (UK) who said there was no difference between black only
and grayscale.
So today I made a black and white print using all the colours as per
Paul Roark's method (with grayscale box unchecked) and the resulting
print appears virtually identical to the BO print (or was it BO). So
should I have 'black only' in that box? I would be grateful for any
help.
Charlie Francis
Re: First black and white print
2006-05-02 by Chris Ellis
Hi Charlie
Welcome aboard.  I'm sure once you get up and running you'll feel more
positive about working in digital.  I'm sure it doesn't have all the
answers, but then working in the darkroom isn't perfect either!  You
need to find an approach which works for you - but it unfortunately
(and like working in the darkroom) it doesn't happen straight away.
It sounds to me like the printer driver may have not updated properly.
 You can check this by finding your printer properties - it should
show you the driver version somewhere.  (I'm not at home at the moment
so can't be more specific about how to find these - also I use Windows
which you may not.)
If the correct version isn't there you might need to delete the
printer from the list of printers and then reinstall.  It might also
be worth trying a reboot with your printer switched off before
reinstalling the drivers.
When I used the 'grayscale' option (i.e. before I upgraded the printer
driver) I had colour inks installed, and it definitely laid down a lot
of blue ink.  The differences between black only and an R2 neutral
print will probably be more subtle (I don't have a neutral inkset so
again I'm a bit vague).  If you have the warm inks, then the prints
will appear noticeably different.  BO prints often have dots in
highlights which are visible to the naked eye.  The R2 prints will
most likely be much smoother.
Hopefully this will be of some use.  It sounds like you're making
headway with the R2 inks anyway - how are you getting on with these?
Good luck
Chris
> and grayscale.
> help.
> Regards
> Charlie Francis
2006-05-04 by chas4452
Hi Chris
Thanks for your reply. I was waiting to hear what Epson technical
said about not being able to get 'black only' checkbox. They have
just sent me an e-mail saying that with the Epson R220 printer I
will not be able to get 'black only' regardless of what driver I
have.
I am sure that you wrote that you had downloaded the 5.5a driver and
got the 'black only' box. Perhaps you can verify this so I can
challenge them. When I tried to download the 5.5a driver a message
came up saying it had done so successfully but in the preferences
box, it still says 5.5 version.
I bought the R220 so I could have a go at BO and don't want to give
up yet!
Regards, Charlie
- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Chris Ellis"
<christian.ellis@...> wrote:
> Hi Charlie
more
You
properly.
moment
Windows
> which you may not.)
also
printer
lot
so
these?
> Good luck
> Chris
some
have
UTR2
understood
checkbox
had to
This I
Epson
only
> > and grayscale.
per
resulting
BO). So
any
> > help.
> > Regards
> > Charlie Francis
2006-05-05 by Chris Ellis
Hi Charlie
My print driver definitely has a black only option (I can send you a
screen shot if you want to forward this on to Epson).
I notice that there are different versions of the driver on the US and
European sites.  If you haven't tried the US version then this might
be worth a shot:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=60202&prodoid=58654761&infoType=Downloads&platform=Windows
A confusing sidenote:  I downloaded a driver labelled 5.5a from some
website.  I can't now remember which but I think it was probably the
US one - as US users seem to have no problem with this.  I just
double-checked the version of the driver as it appears in the printer
properties and it's listed as 5.51.    When you look at the US website
it does give this as the 'core driver version'.  There is nothing
which mentions a '5.5a' version number anywhere.  ????
Hope this helps - not sure it will though!
Chris
2006-05-06 by chas4452
Hi Chris
It worked!! I have got a Black Only checkbox. Many thanks for giving
me the US Epson link. So if there are any Brits out there who are
thinking of getting an Epson R220 printer and doing BO printing, you
need to download the latest driver from Epson US website not UK.
Thanks again Chris.
Charlie
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Chris Ellis"
> Hi Charlie
a
and
might
> be worth a shot:
form=Windows
some
printer
website
> Chris
