Re: Printing in o.s.x 10.3.9 with 1160 and 1280f
2006-05-02 by Clayton Price
For whatever it's worth, I tried for a long time to make the drivers work in OS10. I printed for several years on two 1160's with Piezo inksets. They worked fantastic with OS 9. So when I upgraded my computers, I kept OS 9 and went back and forth for printing. A pain in the neck, but great prints. It was with great pleasure that I switched to the new NK7 inks on a 2200, and retired the 1160's, as well as OS9. Those problems, at least, are behind me. Now, I'd like to warm up those neutral K7 inks and can only do so by looking for a warmer paper. An suggestions from someone? Clay
> Date: Tue, 02 May 2006 09:37:08 -0400 > From: siobhan mcclory <siobhan@...> >> >> There is an Epson 1160 OS X driver...Printer Driver v1.2bA....Go to >> Epson's >> website it's there. >> > Hi John, > > I found the driver, (listed under all printers, and not inkjet). I > actually had tried this driver in the past and the printer would work > one > minute and not the other which is why I installed the GIMP print one > which > has stabilized the printer. (the settings became an issue recently > because > I am now trying to use same printer for printing images with Piezo and > thus > need the settings) > 1. Do you or can anyone guide me as to which is the better driver to > use. > 2. In the GIMP print one there are several settings that I do not > know > what the settings should be and there does not seem to be a way to turn > color sync off. Additionally under printer features, Dither algorithm > has 6 > options. > Any suggestions would be greatly appreciated. Siobhan
