Eboni Ink UK
2006-05-16 by geoffreybillett
Is Eboni ink available in UK? If not what readily available ink would people recommend for a 2100 . Thanks.
2006-05-16 by koloshor
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "geoffreybillett" <geoffbillett@...> wrote: > > Is Eboni ink available in UK? If not what readily available ink would people > recommend for a 2100 . Thanks. Moderator, this needs to be a FAQ! The inks are actually made by a company in New York called Image Specialists. If my database is correct, Eboni is actually Image Specialists WJ1106 (but I would email Image Specialists to confirm). MIS is just one US distributor, along with WeInk (aka GetInkExpress). Distributors get ink from Image Specialists in 1/2 gallon (about 2 liter) and gallon (4l) jugs, or 5 gallon (20l) drums, and load it into 4 ounce (or 125ml bottles, on your side of the pond) or printer carts and sell it to those of us who can't afford gallon jugs of ink (or don't want to handle or store them. If you've even the results of a 5 gallon ink spill... But I digress) Image Specialists has three European distributors: TECNOdigital sas in Italy, Gemini Colours B.V. in the Netherworld, and A&V Slovakia, s.r.o. in Slovokia (obviously). http://image-specialists.com/default.asp Hope this helps. Ciao! Joe
2006-05-16 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "koloshor" <koloshor@...> wrote: > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "geoffreybillett" > <geoffbillett@> wrote: > > > > Is Eboni ink available in UK? If not what readily available ink > would people > > recommend for a 2100 . Thanks. > > Moderator, this needs to be a FAQ! > > The inks are actually made by a company in New York called Image > Specialists. If my database is correct, Eboni is actually Image > Specialists WJ1106 (but I would email Image Specialists to confirm). > MIS is just one US distributor, along with WeInk (aka GetInkExpress). I could not get Walter to confirm nor deny that Eboni was the same as anything when I asked last year. Having both Eboni and the WJ1106 side by side, all I can say is that they are similar, but not the same. The Wj1106 seems superior to the Eboni that I have left. The Eboni "folds" over into gray much sooner (density reciprocity???) than the WJ1106 with swab tests on German Etching. I seem to recall the same when printing. The WJ1106 holds density way out to almost the real 100% limits of the hardware (or at least doesn't reverse as quickly), this is just short of producing puddles of ink. MAybe I have some old Eboni, as the do smell the same. > Distributors get ink from Image Specialists in 1/2 gallon (about 2 > liter) and gallon (4l) jugs, or 5 gallon (20l) drums, and load it into > 4 ounce (or 125ml bottles, on your side of the pond) or printer carts > and sell it to those of us who can't afford gallon jugs of ink (or > don't want to handle or store them. The smallest size I would have been able to get is gallon each color, but I never had enough people interested in splitting those gallons to move forward. Price last year was around $42 per 500ml (pint), plus shipping, and I was going to doal it out at cost or just a little over. Had bottles all picked and everything. > > Image Specialists has three European distributors: TECNOdigital sas in > Italy, Gemini Colours B.V. in the Netherworld, and A&V Slovakia, > s.r.o. in Slovokia (obviously). > Good to know, I'll file this away for use on the diferent forums. You guys in the UK really need some good alternative pigment ink sources. If any of you are set up for a business, you might make a killing on selling ink over there.
2006-05-16 by kenstrain2000
I heartily recommend buying from MIS and using the cheapest shipping, unless money is no object. Ken (customer in the UK). --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "geoffreybillett" <geoffbillett@...> wrote: > > Is Eboni ink available in UK? If not what readily available ink would people > recommend for a 2100 . Thanks. >
2006-05-16 by John Moody
The website currently lists UltraPro WJ1106 as PK, and WJ1082 for MK. Could there be a mix-up somewhere? Best regards, John Moody
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Greg Sent: Tuesday, May 16, 2006 2:34 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Re: Eboni Ink UK --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "koloshor" <koloshor@...> wrote: > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "geoffreybillett" > <geoffbillett@> wrote: > > > > Is Eboni ink available in UK? If not what readily available ink > would people > > recommend for a 2100 . Thanks. > > Moderator, this needs to be a FAQ! > > The inks are actually made by a company in New York called Image > Specialists. If my database is correct, Eboni is actually Image > Specialists WJ1106 (but I would email Image Specialists to confirm). > MIS is just one US distributor, along with WeInk (aka GetInkExpress). I could not get Walter to confirm nor deny that Eboni was the same as anything when I asked last year. Having both Eboni and the WJ1106 side by side, all I can say is that they are similar, but not the same. The Wj1106 seems superior to the Eboni that I have left. The Eboni "folds" over into gray much sooner (density reciprocity???) than the WJ1106 with swab tests on German Etching. I seem to recall the same when printing. The WJ1106 holds density way out to almost the real 100% limits of the hardware (or at least doesn't reverse as quickly), this is just short of producing puddles of ink. MAybe I have some old Eboni, as the do smell the same. > Distributors get ink from Image Specialists in 1/2 gallon (about 2 > liter) and gallon (4l) jugs, or 5 gallon (20l) drums, and load it into > 4 ounce (or 125ml bottles, on your side of the pond) or printer carts > and sell it to those of us who can't afford gallon jugs of ink (or > don't want to handle or store them. The smallest size I would have been able to get is gallon each color, but I never had enough people interested in splitting those gallons to move forward. Price last year was around $42 per 500ml (pint), plus shipping, and I was going to doal it out at cost or just a little over. Had bottles all picked and everything. > > Image Specialists has three European distributors: TECNOdigital sas in > Italy, Gemini Colours B.V. in the Netherworld, and A&V Slovakia, > s.r.o. in Slovokia (obviously). > Good to know, I'll file this away for use on the diferent forums. You guys in the UK really need some good alternative pigment ink sources. If any of you are set up for a business, you might make a killing on selling ink over there. [Non-text portions of this message have been removed]
Thanks for your replies everyone. A forum member from UK has offered to sell me some so I will have enough at least to get a feel for it. If bitten it looks as if Ken's solution is the only solution :-(. I hope it lives up to Clayton's sterling recommendations ;-) Geoff ps great website Clayton --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "kenstrain2000" < kenstrain2000@...> wrote:
> > I heartily recommend buying from MIS and using the cheapest shipping, > unless money is no object. > Ken (customer in the UK). > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "geoffreybillett" > <geoffbillett@> wrote: > > > > Is Eboni ink available in UK? If not what readily available ink > would people > > recommend for a 2100 . Thanks. > > >
2006-05-16 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Moody" <moodymz3@...> wrote: > > The website currently lists UltraPro WJ1106 as PK, and WJ1082 for MK. Could > there be a mix-up somewhere? > > Best regards, > John Moody Yes, you are correct, there was a mix up. WJ1082 looks more like it.
