Re: [Digital BW] 2400 Ink Cnfiguration COlor Density
2006-05-25 by Ender100@aol.com
Ink Configuration certainly works, because I use it sometimes to increase ink density for digital negatives on Pictorico OHP film. I have measured the increase in density and it is quite a bit if you take it from neutral "0" to "+50", (say from Log 2.5 to Log 4.0 UV transmission density) though on current Pictorico OHP film, after about +15 you start to get puddling with the R2400. I am wondering if some other setting you are using is negating the Ink Configuration setting. I haven't tried it, but could it be that the special B&W printing feature negates this, since you have some other similar controls in the B&W setup? Best Wishes, Mark Nelson Precision Digital Negatives--The Book PDNPrint Forum at Yahoo Groups www.MarkINelsonPhoto.com In a message dated 5/25/06 2:59:55 PM, tktincnm@... writes: > Hi All: > > I have run across a perplexing problem while printing B&W with my > Epson R2400 printer. I am using Clayton Jones' recommended settings > (Paper Type : Velvet FIne Art; Quality:Best Photo; Print Option : > High Speed; COlor Management: Advanced B&W; Ink Config: -5% Color > Density; TOne: Light; Printer Profile: No Color Management; Image > Profile: Dot Gain 20%; 16 bit Greyscale; 720 dpi; Print COlor: > Neutral). I ran a test print of a 21 step steptablet and wanted to > further reduce the ink loading. I reduced the Ink Configuration to - > 10% from -5 % and there was no observed change in ink density on a > testprint. I then tried -15%, - 25%, and all the way down to - 50% > on the color density slider with the same results - no observable > reduction in ink density! Minus 50&% is all the lower the slider > goes. > > I contacted Epson tech support and their reply was "The effect is > very slight and can be hard to see. Try adjusting it down even > further, or adjust in PhotoShop to reduce the amount of > saturation/black levels." So much for tech support! > > Has anyone out there ran into this problem - the non-working color > density slider under Ink Configuration in the Epson printer driver > with Print with Preview out of PS CS2 using a R2400? > > Thanks in advance, > > TK Thompson > [Non-text portions of this message have been removed]
