Roller marks
2006-06-16 by Brian Chapman
A couple questions about roller marks... 1. How do I know if a "band" on the paper is from a roller? - i have a band on one side of the paper, about half an inch wide and 20% from the edge, that looks like the paper is compressed and maybe there is some ink there than can be rubbed off with some brisk rubbing from a t-shirt. if there is a print on the paper (the example above was when the paper was rolled through the printer without printing) there appears to be a scuff type mark within that same half inch band, most noticably in the darker tones. 2. Is that fixed by this? http://inksupply.info/index.php? _a=knowledgebase&_j=questiondetails&_i=75&nav=+%26gt%3B+%3Ca+href%3D% 27index.php%3F_a%3Dknowledgebase%26_j%3Dsubcat%26_i%3D1%27%3ETips% 2C+Tricks%2C+and+Terms%3C%2Fa%3E 3. Will pinning the roller up harm the ability of the printer to feed certain types of paper? 4. Is it better to clean the roller rather than pin them up as described in #2? If so, is there an article with instructions on cleaning the roller(s)? Thanks, Brian http://www.brianchapmanphotography.com
