Problem Printing Black in Corner With QTR
2006-06-17 by michaelrosensf
Sometimes I like to burn edges and corners gradually to black. I've always had a problem doing that with QTR and my 2200. The problem I'm showing here looks like my 2200 stops laying down black ink when it gets to the corner at the right side of the printer. (I'm using High Speed = "better", not "faster". I've scanned some test strips and put the result on my web site demonstrating the problem - and "solution" - at http://www.shaynew.com/temp/cornerproblem.jpg. I've used a Photoshop adjustment curve to exaggerate the differences somewhat. The top strip is a print from QTR, 2.4.1. I used Roy's QTR Gray Lab space and printed with Let Photoshop Determine Colors, QTR-Gray Matte Paper, Perceptual, Black Point Compensation = ON (although I've seen the problem with other settings). Print Resolution = 1440 super and High Speed = "better". The left corner of the strip, which came out of the right side of the printer, shows the problem; the corner should be at least as black as the area next to it. The right, which also goes towards black, is fine (but if you look very closely, you'll some banding). The next strip down is the same strip flipped horizontally (Flip Canvas Horizontally). What was the left corner, now on the right, is fine (except for some banding). What was the right corner, now on the left, shows the same problem! Is there something wrong with my 2200, that it has a problem printing black at its right side? No. The bottom strip was made with one of the Roark curves and the Epson driver. Everything is fine! And no banding. I printed on EEM, using the curves that came from Roy's installation, at 25/75 cool/warm. Anybody see anything like this? I'm happy to email a file to someone to print on her 2200 printer. Michael
