Ed-
I'm not sure what you're doing here in "printing a test file." If
the step wedge is going to be used to produce a QTR ICC profile, you
should use "let printer determine colors" ("no color management" in
CS2) because you don't want PS to change the numbers sent to the
printer. If you are already using a QTR ICC printer profile, you
should use "Let Photoshop Determine Colors," and you should select
as the printer space the ICC profile you created. The fact that the
file is untagged is not relevant because PS is going to assign the
default working space for screen display and modify the numbers sent
to the printer (to match the screen) if PS is managing color.
As an aside, if the printer space is the same as the default working
space (or the document profile), then it doesn't matter which setting
you select.
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "edrudolpho"
<erudolph@...> wrote:
> I was printing out a stepwedge tonight and it suddenly hit me that
I don't know what
> difference there'd be between printing the untagged file with No
Color Management and
> printing it with Let Printer Determine Colors. Does it make any
difference which way you
> print the test file if you're using the ABW function of the Epson
driver? Seems to me it Show quoted textHide quoted text
