Using UT2 in an R1800?
2006-08-01 by Dale Lum
Hello,
I've got an Epson 1280 which has three clogs from hell. I've tried every
cleaning method I can find, with no luck. I think it's time to throw it out.
From what I've read, the R1800 seems to have fewer clogging problems. First
of all, is this true? Secondly, I've got a large amount of UT2 that I would
hate to go to waste. Is it possible to use UT2 with the R1800?
thanks,
Dale
Hello,
thanks,
Dale
RE: [Digital BW] Using UT2 in an R1800?
2006-08-01 by Paul Roark
>...Is it possible to use UT2 with the R1800?
Not easily.  If you have a rip and are good at making your own curves it
might work.  I've never tried B&W inks in an 1800.
