On Topic and OT: Epson R2400 and Ink Density Settings (B&W & color)
2006-08-28 by Howard Slavitt
I got started down this road based on reading this forum and trying
out Clayton Jones' ABW workflow for my Epson R2400.  Great articles!
I find Clayton's work flow easier and more versatile than using QTR
on my Epson 2200, which was my previous workflow.  The blacks on the
R2400 really help make black and white printing yield richer results,
IMHO.  For my on topic point -- for those of you who like semigloss
papers like I do, the Epson Semigloss paper works great with
Clayton's workflow and ABW.  I find I'm able to tone the Epson
Semigloss to both get selenium/blue tones and to get rich deep
browns.  A great versatile paper.  It bronzes much less with the 2400
and ABW than it did using the 2200/QTR workflow. . .  Now for my off
topic (color) question.  I'm in the process of ordering COLOR (bad
word around here) printer profiles for my Epson R2400. I'm going to
profile Museo Silver Rag at the "Best Photo" (2440 dpi) setting.
Based on Clayton's suggestion for using the Museo SR for ABW, I was
going to set my color ink density at -3% to get a bit less ink, to
hopefully make it easier to profile and get better shadow separation.
(In ABW mode, per Clayton's suggestion, I use a -4% color ink density
setting, a bit more conservative than his suggested -5% setting.) I
ran tests and could see slightly more shadow separation at -3%. Has
anyone else tried profiling the R2400 for COLOR prints with a color
ink density setting of something other than zero? Any
comments/recommendations? I've searched for more information on the
color ink density setting on the web and have found a few comments,
but they're few and far between. My concern is that by setting the
ink density to -3% I may be limiting the DMAX I can get, or the
saturation, but I figure in any event a -3% setting is pretty
conservative so it shouldn't limit the gamut too much. . . I'm also
getting profiles made for the Epson SemiGloss paper. Here, I figure
I'm better off just using the Epson driver and "0" color ink density
setting, unless others have different experiences. I figure Epson
probably got this one close enough; if I had my own densitometer and
color profiling software I might be able to improve on things, but
that's way beyond the amount of time and effort I'm willing to put
into this. Thanks for any insights. . .  BTW, I was going to use
Cathy's profiles for $40 each.  She's gotten good reviews for her
profiles for years on the web.  . .  Or can someone share their
experiences with the inkjetart.com color profiles that are only $25
each?  Thanks in advance.
Re: On Topic and OT: Epson R2400 and Ink Density Settings (B&W & color)
2006-08-28 by bvalente
Howard
My best results with 2400 and SR are when I set ink density at -3%
and the ABW as "light". Sounds like our notes roughly line up
Cheers
Brian
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Howard Slavitt"
articles!
results,
2400
off
separation.
density
density
and
2006-08-28 by jkohn_home
You may be limiting your gamut a bit in the upper midtones and
highlights with that approach, but I can't really say how much. One
thing you might want to do is try the different media settings to find
out which gives you the best separation in the shadow tones. I recently
profiled Innova F-Type Gloss, which I believe is pretty similar to
Silver Rag in many ways (gamut, dmax, etc).  I found that using the
Epson Semigloss  media setting with ink density at it's default '0'
position gave very good results.  The semi-gloss media setting seemed to
do better in the shadow tones than the luster setting.
