Re: [Digital BW] On Topic and OT: Epson R2400 and Ink Density Settings (B&W & color)
2006-08-28 by CDTobie@aol.com
In a message dated 8/28/06 10:19:57 AM, howard.slavitt@... writes:
> Has
> anyone else tried profiling the R2400 for COLOR prints with a color
> ink density setting of something other than zero?
Sure; I've built PrintFIX PRO profiles for K3 printers on various media with
ink density settings reduced by these amounts, and significantly more. It a
compromise, to some degree, between shadow detail and color gamut. So I'm
working on tools to give me both. A more direct answer: a modest reduction like -3
should be   no problem in building a color profile, may improve shadow detail,
and will hardly effect color gamut.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
2006-08-28 by Howard Slavitt
Thanks, C. David.  (BTW, I purchased my first custom profiles from
you, way back when, when I had an Epson 1200 and was using
MediaStreet inks. . . . You don't still sell custom profiles do
you?)  . . .  What about for profiling Epson Semigloss, do you think
I might also see an improvement in shadow detail with little effect
on color gamut with a -3% ink density setting? . . .  Can you
recommend either Cathy's profiles or inkjetart.com to use as a
profiling service?
Howard
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, CDTobie@...
media with
more. It a
So I'm
reduction like -3
shadow detail,
> C. David Tobie
> Datacolor Inc.
> CDTobie@...
> www.colorvision.com
In a message dated 8/28/06 10:48:51 AM, howard.slavitt@... writes:
> you?)  . . .
No,   believe in burning my bridges behind me, and am focussing on making
user-built ICC profiles so good, so easy, and so affordable, that there will be
little justification for jobbing it out anymore...
If you were using PrintFIX PRO, I would tell you to go to the Media Setting
Test Print page, and print it at all available media settings, and once you had
selected one, at a range of ink density reductions, and to study the results
to see what the optimum choice for balancing shadow detail and gamut is for
your printer/paper/ink combo, using the example images in the help file for
assistance. With other tools, you are on your own to perform, and interpret these
steps. Actually, I believe you can still access the latest version of PrintFIX
PRO from the US site (www.colorvision.com) without any type of restriction.
You could download it, and use it in demo mode to perform these checks.
The next version of PrintFIX PRO (which should be a free upgrade to all exist
ing users) will have advanced tools for controlling shadow detail, among many
other new features. Also (this being a black and white list) there will be new
black and white features as well. Keep an eye on Photokina for more info.
>   Can you
> profiling service?
Cathy certainly has many fans. I've worked more with Chromix. And our old
partner Pantone has decided, rather late in the game, to offer profiling
services. I suspect they may charge a premium for the Pantone name however. But my
suggestion is to build your own, its more direct, offers more control, and I
certainly couldn't imagine doing it any other way these days.
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
