K3 inks+Innova F-Type Gloss Ultrasmooth+ Ren Wax
2006-09-03 by TK Thompson
A while back I reported on tests of various coatings for Innova F- Type Gloss Ultrasmooth paper. The prints were made on an Epson 2400 with stock Epson K3 pigmemt inks. I reported that a coat of Renaissance Wax on the surface gave the best shadow detail and eliminated any gloss differential. I just ran some prints for a client and ran into a different problem. I let the prints "age" for ~ 24 hours after printing before applying any coating. I then coated with the ren wax I reccommended, let it dry for about 3 hours, buffed with a soft towel and put them away for the night. The next morning I noticed a blemish in the sky, of course, on one print which wasn't there when I waxed them the night before. Apparently the solvents in the ren wax "lifted" the epson pigment ink in that particular area of the image. It was a spot about 1mm in diameter. I tried spotting it with spotone and dyes that I use for gelatin silver prints and it didn't work - the wax prevents conventional spotting medium from adhering/pentrating into the paper. So scratch one fine print!!! I have quite using ren wax on any of the new fiber glossy papers (Innova F-Type, Crane Silver Rag, and Hahnemuhle Pearl)printed using Epson K3 inks. I now use Premier PrintShield spray only. It looks almost as good as ren wax (really splitting hairs to tell the difference), protects the surface of the print, deepens the shadow detail, and still completely eliminates any gloss differential problems in the highlights. Just thought I would pass this on so others don't run into the same problem. We get old too soon and smart too late! Cheers, TK
