Re: Mixing NK7 & Sepia in the cartridges
2006-09-06 by Clayton Price
Hi -
I'm working on a 2200 with Piezo NK7 Inks and Hahnemuhle Photo Rag.
As much as I like  these new inks (a lot), I preferred the Warm Black
color of the previous
Piezo Tone ink set.
So I'm about to experiment by removing some neutral black from some
cartridges, and adding an equal amount of sepia (via syringe) - not
to create split toning necessarily, but to generally warm the print
up.  In a reference to split toning, Jon Cone recently wrote,
"...Sepia should only be prevalent in the shadows... the mix is in the
mid tones - quartertones -- and  highlights being neutral..."
Has anyone on the list tried something like this, or could you share
some of your thoughts about it?
The immediate questions are which cartridges to leave as is (if any)
and which ones to add the sepia.  And equally important would be
proportion of
Sepia to Neutral.  This emerges as the central question, because of
the economics. One would like to get pretty close on the first one or
two tries.
Thanks in advance for your help.  I'll report back on results.
Clay Price
RE: [Digital BW] Re: Mixing NK7 & Sepia in the cartridges
2006-09-06 by David Whistance
Hi Clay
Why not get some of the new Sepia K7 inks from Cone for the darker inks
instead?  Although this approach is more expensive it will make your life
easier when the time comes to change the cartridges!
David Whistance
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Clayton
Price
  Sent: 06 September 2006 16:57
  Subject: [Digital BW] Re: Mixing NK7 & Sepia in the cartridges
  Hi -
  Piezo Tone ink set.
  proportion of
  two tries.
  Clay Price
2006-09-07 by john dean
Hi Clayton,
Here is the guy at InkJetMall that you should talk to: Wells Smith
InkjetMall
888-426-6323 EXT 103
Tyler just got back from teaching a workshop out there in Vermont and
he has glowing reports of the printmaking going on, specifically in
the area of split toning with the k6/k7 inks. I for one just can't
wait to go down that road. If you talk to him ask if it is possible to
go the other way around - sepia in the highlights and neutral in the
shadows. I'm interested in trying that configuration too, but right
now have too many irons in the fire.
John
