I tried it in the 13x19 size. It seemed to cause major clogging on
both my 2200 and my 1280. I'm going to try it again using the thick
paper feed on the 2200 to see if that helps. It was suggested that
the thickness or rigidity of the paper might be causing greater than
normal curl forcing the paper against the print heads. I've had
excellent results with the 11x17 regular Fiba Gloss, so I'm thinking
that it might have something to do with the greater length of the
paper. Especially since the clogging seemed to begin towards the end
of the print.
Mike
On Sep 20, 2006, at 1:06 PM, Terry Ritz wrote:
> Has anyone tried Innova's new F-Type Gloss Warmtone? Is it identical
> to the regular F-Type Gloss, other than the impact of a warmer paper
> base? Also, how does it compare to Silver Rag (paper base colour,
> general impressions, etc.).
> This paper sounds very interesting.
> Terry.
