Re: [Digital BW] Epson 3800 and long sheets of paper
2006-09-25 by Brian
Although the 3800 doesnt accept rolls of paper, isn't it possible just
to get around this by cutting up a roll and feeding it manually into
the printer? Isn't it possible just to set a custom paper size in the
Epson printer driver?
If this would work, I will probably buy one.
Hi
Permajet papers have been available in A2 sheets for a few years now - see
http://www.permajet.com/html/products_paper_range.html
I suspect most other manufacturers will follow suit if the 3800 sells, as I
expect it will. I use Permajet Delta Matt in my 2100 at present, and I'll be
first in line for a 3800.
Brian
2006-09-25 by Walt Mucha
>-----Original Message-----
>From: architekphoto [mailto:paul@....uk]
>Sent: Monday, September 25, 2006 02:50 AM
>To: DigitalBlackandWhiteThePrint@yahoogroups.com
>Subject: [Digital BW] Epson 3800 and long sheets of paper
I don't see why not. This doesen't appear to be a "production" machine. The advantage for roll paper, besides cost, is you can print unattended. I like the idea of not having to switch carts to print gloss/semi gloss material. The downside to cutting up rolls is you have to flatten the paper prior to printing and the time spent cutting down the roll. Time being money, I think I'd just buy the precut paper.
Walt
