refilling sponge-less carts
2006-10-21 by Jerry Blanton
I have a very simple question about refilling the MIS sponge-less
carts for the 2400.  Do I need a separate syringe for each cart or
can I reuse the same one for each color?
Re: [Digital BW] refilling sponge-less carts
2006-10-21 by Tom Baker
Just rinse and dry completely between colors.  Works great.
  Tom Baker
2006-10-21 by Craig Roberts
Since they're very economical, I use a separate syringe for each color.
It's not necessary, but is much more convenient than rinsing between
fillings.
Craig
Washington, DC
Re: refilling sponge-less carts
2006-10-23 by David Keenan
I have been following this thread.
I have found a seller on eBay for the refillable carts.
The question I have is about inks. What do people recommend as an alternative to the Epson K3 inks?
Dave.
Re: [Digital BW] Re: refilling sponge-less carts
2006-10-23 by Tom Baker
MIS inks are one very good alternative.  (www.inksupply.com)
  They also have the spongless carts, and whatever else you might need for loading you own.
  Tom Baker
Dave.
2006-10-23 by Manuel Toledo Quinones
I share Tom's opinion. I bought the K4 inkset about a month ago. I
have been using the profiles that paper manufacturers' provide for the
epson k3 inks. I tried it on several red river papers, moab's kayenta
and epson's enhanced matte, and the results are quite good.
Manuel
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, David Keenan
> Dave.
2006-10-23 by Linda Jacobs
I bought enough to do each color because the process goes much faster.
I refill all at the same time even though only a couple may need it. I
use MIS carts and inks for my R2400. No problems outside of one bad
chip. I keep a couple of sets of chips onhand.
Linda
I haven't refilled the R2400 carts yet, but used MIS refillable's on
the 1280 before. I usually clean the syringe and the botton fill
adapter with hot water and refill the next color. I do several
cleaning cycles until the water comes out clear.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jerry Blanton
SV: [Digital BW] refilling sponge-less carts
2006-10-23 by Peter Oksen
I use one syringe for all. Just rinse it thoroughly in water between
colours, and you shouldn’t have a problem. I also mostly refill all at once
to avoid wasting ink.
Peter
  _____
Fra: DigitalBlackandWhiteThePrint@yahoogroups.com
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] På vegne af Linda
Jacobs
Sendt: 23. oktober 2006 14:58
Til: DigitalBlackandWhiteThePrint@...m
Emne: Re: [Digital BW] refilling sponge-less carts
On 10/21/06, Jerry Blanton <jblanton@yahoo. <mailto:jblanton%40yahoo.com>
Linda
2006-10-23 by Peter De Smidt
Since syringes and needles are so inexpensive, I have one for every ink
color.  Each is labeled, and I do rinse them out after every use. (I
rinse them all at the end.)  I like the MIS 4" needles, and I pick up
syringes at my local Fleet Farm.  They have needles as well, but they're
thicker and shorter.
