Banding and the PS noise filter
2006-10-23 by sagaface
Can someone explain or point me to a source for reading about how to use this filter to
minimize banding? I just Googled but diidn't find anythiing specific.
 Before I got my own 2200, I had a friend who works at the Photographic Workshops in
Maine do some printing for me on his 2200. I saw that he used this filter but wasn't really
paying attention. Now that I have my own 2200 I'd like to know what he did, as I often get
banding in solid areas of midtone, and his prints were band-free.
Thank you!
Sarah
Re: Banding and the PS noise filter
2006-10-26 by Brian Chapman
Hey Sarah,
I've used noise successfully to solve some banding issues.  Inkjet
prints seem to be able to handle quite a bit of noise before it
becomes noticable on the print.  You can also use it to smooth banding
in layer masks - this banding can be visible in the print if you don't
take care of it.  Can you see banding in Photoshop prior to printing?
To use the filter add a new layer (using Layer->New Layer), set the
blend mode to overlay in the dialog and check the box to fill with 50%
neutral gray (I'm not in front of Photoshop while I'm writing this so
I hope I have it right!).  You can then add noise to that layer -
Filter->Add Noise...I use Gaussian distribution and between .5 and 2
for the amount.  I also check the monochromatic box.  You can then use
a layer mask to block out areas that wouldn't benefit from the
addition of noise (and be sure to add noise to the mask afterwards to
eliminate any banding in the mask!)  I find that zooming to 100% works
best.
On the other hand, the problem could be a result of less than perfect
linearization of the printer and someone else would have to help with
that ;-)
Hope this helps...
Brian
http://www.brianchapmanphotography.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sagaface"
use this filter to
> Thank you!
> Sarah
2006-10-26 by sagaface
Brian...thanks so much for digging out this post~ I don't see banding at all in PS before I
print - perhaps because I don't ever use layer masks. I'm definitely going to try your
method....I'll let you know if it helps.
Thanks again!
Sarah
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Brian Chapman"
<brianechapman@...> wrote:
> Hey Sarah,
> best.
> that ;-)
> Hope this helps...
> Brian
> use this filter to
> > Thank you!
> > Sarah
