Lexjet Sunset eSatin paper
2006-10-26 by Steven Karafyllakis
Hello All;
I've spent the last month trying out a paper called Sunset Photo
eSatin Paper 300g
sold by Lexjet. It is reasonably priced, available in all sizes and
rolls, and I'm told its OBA-free (I'm not sure I belive this, but
having no UV light I can't verify) but not acid-free. It is the
heaviest, stiffest RC paper I've seen or handled. It should be quite
easy to use in large sheets without creasing. Here are my
impressions:
I'm getting an uncoated dmax of 2.37 after dry-down, over 2.5 with a
coating. This with MIS K4 inks on an R1800.
Surface color is a bit yellow out of the box, in fact it looks and
measures just
like a satin version of the Costco paper might. There's a glossy
version I haven't yet tried, and probably won't.
Surface texture has been the major dissapointment. It looks very 'RC
papery' with a mechanical stipple similar to Epson semi-gloss or any
other RC luster or semi-gloss paper. If you don't mind that, this
paper is a winner.
The first week of fade-testing it appeared to be getting bluer, but
now it seems to have stabilized at a bit yellower than it started.
The difference is so slight I sometimes see it & sometimes don't
depending on the light. The spectro puts the B value at a starting
average of -3.5 and a 3-week average value at -3.45
Three weeks of south window exposure with sunlight 4-5 hours a day
has
produced no visible or measurable change in the dmax, but a slight
change in
all other densities. From 95% through 70% it has lost .02, and from
65% to 05% it has lost .01. I don't know if this small a change is
statistically
significant, but the change and trend were very consistent, so even
though it is not visible yet, I expect sooner or later it will
become so. Still, this seems
to be a relatively stable paper that would do fairly well under
glass in
normal display conditions.
The weight and heft of this paper are by far its greatest appeal-at
300gsm it feels good in the hand, and doesn't flex as easily as most
RC papers.
And it does print well, with good presence for an RC paper, good
shadow separation, great dmax. It
produces a really nice snappy print that in most ways is better than
any halide RC print I've ever seen.
Not bad, but I'm still looking.
Steve
RE: [Digital BW] Lexjet Sunset eSatin paper
2006-10-27 by Scott West
Steve,
Thanks for the info on the paper.  I'm curious as to how you are using MIS
K4 inks with an R1800?  Could you elaborate on this?
Scott
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Steven
Karafyllakis
Sent: Wednesday, October 25, 2006 10:12 PM
Subject: [Digital BW] Lexjet Sunset eSatin paper
Hello All;
I've spent the last month trying out a paper called Sunset Photo eSatin
Paper 300g sold by Lexjet. It is reasonably priced, available in all sizes
and rolls, and I'm told its OBA-free (I'm not sure I belive this, but having
no UV light I can't verify) but not acid-free. It is the heaviest, stiffest
RC paper I've seen or handled. It should be quite easy to use in large
impressions:
Surface color is a bit yellow out of the box, in fact it looks and measures
just like a satin version of the Costco paper might. There's a glossy
Surface texture has been the major dissapointment. It looks very 'RC papery'
with a mechanical stipple similar to Epson semi-gloss or any other RC luster
or semi-gloss paper. If you don't mind that, this paper is a winner.
The first week of fade-testing it appeared to be getting bluer, but now it
The difference is so slight I sometimes see it & sometimes don't depending
on the light. The spectro puts the B value at a starting average of -3.5 and
Three weeks of south window exposure with sunlight 4-5 hours a day has
produced no visible or measurable change in the dmax, but a slight change in
all other densities. From 95% through 70% it has lost .02, and from 65% to
05% it has lost .01. I don't know if this small a change is statistically
significant, but the change and trend were very consistent, so even though
it is not visible yet, I expect sooner or later it will become so. Still,
this seems to be a relatively stable paper that would do fairly well under
glass in normal display conditions.
The weight and heft of this paper are by far its greatest appeal-at 300gsm
it feels good in the hand, and doesn't flex as easily as most RC papers.
And it does print well, with good presence for an RC paper, good shadow
separation, great dmax. It produces a really nice snappy print that in most
ways is better than any halide RC print I've ever seen.
Steve
Re: [Digital BW] Lexjet Sunset eSatin paper
2006-10-28 by Steven Karafyllakis
Hi Scott, be glad to. Several people on this list are using some
variation on the theme: I have K4 PK in the normal PK slot, K4 LK in
the gloss slot, and K4 LLK in the red slot. I'm of course using QTR
to drive the arrangement, and getting great results. The only down
side obviously is printing color means swapping the R cart ( I don't
swap the gloss) and printing enough to get the LLK out of the head.
I've found it to be more difficult to get the red out when I go back
to B&W, so I do a quick Windex injection into the R head, a cleaning
cycle, and I'm good to go.
The other alternative is a 2K solution, with LK in the gloss slot.
This works very well also, and leaves you ready to do color anytime.
I've found the MIS Pro and K4 inks don't need the gloss as much as
Epson inks because they simply aren't as glossy. If I do need a
gloss coat, I spray it on with a modeler's airbrush-easy, effective
and not as stinky as Premier or other varnishes.
If you're using QTR on a PC and would like to try this, email me of
list & I'll send you a couple curves to get you started if you need.
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Scott West"
<westsdad@...> wrote:
> Steve,
using MIS
> Thanks,
> Scott
