Landscape bright background
2006-10-30 by Bob Cain
I have been having trouble lately photographing in daylight.   My foreground
is sometimes severly overshadowed by the bright light of the sky.  So trees
look to dark, and if I increase the shutter the sky washes out?  Any tips?
Here are some photos that did come out but probably still need work:
http://www.robertcain.info/gallery/2055781
Bob Cain
http://www.robertcain.info/photography
Re: [Digital BW] Landscape bright background
2006-10-30 by Charles Carstensen
Look at Lee Filters, using various combinations of neutral density
graduated filters to get the sky above horizon cut down to allow
proper foreground exposure. Lee system is terrific, although a little
on the expensive side. They have everything you need for landscape
photography.
http://leefilters.com
Chuck Carstensen
> foreground
> So trees
> tips?
> Thanks,
> Bob Cain
2006-10-30 by Tom Baker
If you're shooting film, try an orange and/or a polarizing filter.  If you shooting digfital, be shure you're shooting in raw mode, and a polarizing filter will help with many of the skys.  Raw mode in digital will give you the maximum information to work with.
  Tom Baker
Bob Cain
2006-10-30 by Stephen Castello
On Sun, 29 Oct 2006 21:58:28 -0500, "Bob Cain"
<boblovesphotos@...> had a flock of green cheek conures squawk
out:
A graduated neutral density filter will help the sky.
Stephen
2006-10-30 by CorrPro96@aol.com
In a message dated 10/29/2006 10:01:55 P.M. Eastern Standard Time,
boblovesphotos@... writes:
You need to use a neutral density filter over the bright areas of the  scene.
Split filters are expensive, but you can do better if you make your own  from
sheets of N.D. material. Old sheet film can be used as well. Cut the filter
material (cut with a jagged edge, not straight across) to suit the  scene,
tape it in place onto your lens, and throw it away when you're  finished.
If you are using a view camera or an SLR, it is easy to exactly place the
filtration and see the results. It helps if you first meter the scene so you
know how much density you want. Play with it. Shoot as wide open as you can to
avoid focus on the filter.
Richard (Brooklyn)
2006-10-30 by FRD
If you¹re shooting digital, ND filters (IMO) are pretty useless as you can
either bracket and layer blend (better quality) or layer blend from a single
digital raw file (easier). It¹s a lot more precise, you¹ll save some money
and maybe even sharper images.
The big question for me, however, is using a polarizing filter on a dSLR +
wide angle lens. No matter how I turn it or position myself, the sky gets so
blotchy‹large swaths of dark blue to light blue. I can¹t seem to get all of
it in one color...
> boblovesphotos@... <mailto:boblovesphotos%40gmail.com>  writes:
> Richard (Brooklyn)
I was thinking in terms of b&w for the orange filter.  Obviously, it wouldn't work for color, but the polorazing filter will often do the trick. If not, as was mentioned, the graduated filters, or multiple exposures and blending in PS will work.
  Tom Baker
Bob Cain
RE: [Digital BW] Landscape bright background
2006-10-30 by Eric Neilsen
Split ND filter. ND= neutral density, works for both color and B&W.
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Bob Cain
Sent: Sunday, October 29, 2006 8:58 PM
Subject: [Digital BW] Landscape bright background
http://www.robertca <http://www.robertcain.info/gallery/2055781>
Bob Cain
http://www.robertca <http://www.robertcain.info/photography>
in.info/photography
2006-10-30 by jim kitchen
Dear Bob,
Check this site out for some incremental information, seeing that your work
is digital...
<http://www.farrarfocus.com/>
A few techniques listed at this site, might guide you to a solution outside
your camera, instead of using a filter.
Then again, they probably use them too. Their approach is probably not
novel, but their results and their methods, seem to work.
jim k
2006-10-30 by Kent Messamore
This is an extremely simple problem to resolve if you shoot RAW and use
Photoshop.  Dr. Brown's Place-a-matic allows you to develop two images
correctly exposed for the foreground and the background.  Then merge with a
graduated layer mask.
Kent Messamore
Kent Messamore
K.Messamore@...
  _____
Sent: Sunday, October 29, 2006 9:58 PM
Bob Cain
in.info/photography
2006-10-30 by ronleshuff
Yes and it's being overly used to PP images that have no shadow and completely one dimensional.  It certainly is a useful tool, but one that is being abused.
  What I don't understand is the fawning over these captures that look  faded out, colorless, muted, and no "pop" IMHO-----ron s.
  Sent: Monday, October 30, 2006 6:47 AM
  Subject: RE: [Digital BW] Landscape bright background
  Kent Messamore
  Kent Messamore
  K.Messamore@...
  _____
  Bob Cain
  in.info/photography
  Checked by AVG Free Edition.
  Version: 7.1.408 / Virus Database: 268.13.17/505 - Release Date: 10/27/2006
Re: Landscape bright background
2006-11-01 by Bob Cain
Wow,
Thanks for the overwhelming responses.  I will certainly implement what I
can.  Here is a basic summary of what everyone said:
   1. Shoot in Raw mode.
   2. Get it right the first time, take many shots.
   3. Blend two exposures / bracket and layer blend
      1. **This is also called High Definition technique
      2. Use a tripod and bracket the exposure and reassemble using
      HDR (high-dynamic-range)
   4. Buy a graduated neutral density filter, but many favored the
   bracket method.
   5. Use a contrast mask.
   6. Use a polarizing filter.
      1. Again many favored the bracket layer method.
   7. Use and create your own Split filter.
   8. Use "RAW Shooter Essentials".(replaced my adobe)
   9. Use "bibblelite/bibblepro (4.9.0)"
Much appreciated by everyones response.
Bob
www.robertcain.info
> foreground is sometimes severly overshadowed by the bright light of the
> sky.  So trees look to dark, and if I increase the shutter the sky washes
> out?  Any tips?
> Thanks,
> Bob Cain
Bob Cain
http://robertcain.smugmug.com/photography
