Re: [Digital BW] Just what is Gamma? (and why should I care?)
2006-11-11 by CDTobie@aol.com
In a message dated 11/10/06 6:41:02 PM, rcooke@... writes:
> On the QTR site there is a page that lists "Ideal
> Densities for Various dMax" which shows a 0.682D for the 50% for a
> gamma of 2.20.  So I'm confused on which ones to use for my curves.
> My question to all of the experts out there is:  Is there some web
> site or reference work that explains all of this?  I'l like to be able
> to print the same image onto different papers and have them look similar.
QTR is a great program at a modest price; with limited documentation, and
scattered tutorials. The enthusiasts who use it seem to enjoy the challenge, but
it certainly limits popular usage. Gamma refers to a single number curve that
adjusts the measurable linearity of a ramp, in this case a gray ramp. The
human eye's response curve, compared to the linear values measures by a spectro,
are at gamma 2.2. AdobeRGB, sRGB, and Gray Gamma 2.2 (obviously, in this last
case) are all gamma 2.2 spaces. Monitors are typically calibrated to gamma 2.2
as well. So with all the stuff you'll need to learn, you can simplify your
life by just starting out assuming gamma 2.2 for now. To see a gamma curve in
action, open a grayscale file in Photoshop, go to the "curves" command, place a
point in the center of the linear (straight diagonal) curve, type in 128 as the
starting value, and then other values in the lower box. The results will be
differing gamma curves. At gamma 2.2 (which you'll get in any of the spaces
noted above), 128 is not 50% gray, but it shows the concept of how a single value
can define a gamma shaped curve.
C. David Tobie
Product Technology Manager
ColorVision Business Division
DataColor Inc.
CDTobie@...
www.colorvision.com
