4000 BO Banding
4000 BO Banding
2006-11-25 by Shilesh Jani
Hello All,
This is crossposted. I have not used the BO method on my 4000 in quite
a while. When I tried today, it shows very prominent banding - when
high speed is checked or not. I am using EEM setting at 1440 ppi.
I have cleaned the nozzles, done a power-clean, and used
the "alignment" function in the driver, all to no vail. The nozzle
checke are coming out fine.
Help?
Shilesh
Re: 4000 BO Banding
2006-11-25 by Greg
Did you pull the cartridge out and shake it? The pigment might have
settled a little. You'll also need to clear everything from the lines
in order to see any results. This is just a guess, but it does happen.
