--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Terry
Ritz" <t.ritz@...> wrote:
> I'm relatively new to refilling my 2200 cartridges (MIS Pro),
having done
> around a half dozen cartridges so far. I just tried to fill 3 more
and the
> first is fine but last two did not work. My chip resetter (SK168-
II) flashes
> a few times and then turns solid red when I try to reset chips now.
The
> printer of course will not start up, showing errors on the last two
> cartridges that would not reset.
> Do I have a bad chip resetter? Any tricks or workarounds?
> Thanks,
> Terry.
Interesting! I had the same "problem" with the SK168 on 2200
cartridges. Not having alternative cartridges available (I'm using
MIS refillables), I simply held the SK168 in place for 30 - 40
seconds after solid red appeared. The 2200 accepted those cartridges
without complaint.
The SK168 had changed state in some fashion in the transition from
blinking to solid red and, without alternatives, it did not cost much
to hold the SK168 and cartridge together for an extended period. I
have no idea why it worked; difference in Earth's magnetic field
between your place and mine?
Reinald
