Re: [Digital BW] Re:Grayscale Vs Color (was PFP with UT7)
2006-12-03 by CDTobie@aol.com
In a message dated 12/2/06 7:23:13 PM, claudej1@... writes: > Has anyone found any differences between 2 prints from the same file > printed with their favorite method as Grayscale vs. RGB?? > A fairer test is to do it the other way: convert a grayscale image to RGB, print both, and the results (bia my workflows at least) are identical. The RGB to gray conversion is making choices about channel mixing, that could be the cause of your differences. If you desaturate the image before conversion that should eliminate the issue, as the three channels will be identical. Going from AdobeRGB to Gray Gamma 2.2 is a proper conversion, as they share the same gamma. C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@... www.colorvision.com [Non-text portions of this message have been removed]
